Innovative performance chip - MPG increase?
Discussion in 'Gen 4 Prius Fuel Economy' started by Branchingout3, Mar 17, 2023.
  1. Branchingout3
    Branchingout3 Junior Member
    Pine City, Mn
    2022 Prius
    I was looking at accessories for my 2022 Prius LE and I came across an Innovative performance chip that's supposed to add horsepower, torque and MPG. I never really thought to see the words Prius and performance in the same sentence, but they managed it. It's only $90 so if it works even a little it would pay for itself in no time. Has anyone had any experience with these? Any thoughts on the subject?
  2. Branchingout3
    Pine City, Mn
    2022 Prius
    Well, I bought it anyway. It was only $90. It will arrive next week Thursday so we'll see how it does. I drive 120 miles a day on the highway and in the winter with snow tires and cold I get between 44 and 48 mpg. It will be interesting to see if it boosts it up a bit.
    bisco and audiodave like this.
  3. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    I wouldn't put performance parts on a car that wasn't designed for that purpose. You are more likely to break something that is expensive to fix.
    Pulse07 likes this.
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,546
    6,621
    Texas Hill Country
    Where does the chip go? The obd2 port?
  5. fuzzy1
    10,603
    The website gives insufficient information to distinguish the product from a placebo. I can't even get any installation instructions without first handing them personal identifying information.
    A few prior similar product offerings gave enough information to very clearly identify that they were placebos.
    #5 fuzzy1, Mar 19, 2023
  6. bisco
    52,403
    all the best with it, looking forward to progress reports!
  7. fuzzy1
    10,603
    Here is a product tear-down and review:
    https://carperformancechipreviews.com/innovative-performance-chip/
    For those of us who had careers in designing and building electronic products on circuit boards, this board is "interesting", displaying several features that immediately jump out to knowledgeable viewers.
    So, by altering the Intake Air Temperature reading, it is not a placebo. Though some users might end up wishing that it had been just a placebo.
    #7 fuzzy1, Mar 19, 2023
  8. CR94
    CR94 Senior Member
    2,752
    1,207
    Northwestern S.C.
    P.T. Barnum supposedly said ...
    Pulse07 likes this.
  9. rjparker
    10,546
    6,621
    Texas Hill Country
    I have heard the module wires into the intake mass air flow sensor or iat and puts a resistor in parallel with the signal wires. They then tell you to disconnect the 12v battery overnight so the system will relearn with their module t-tapped in.
    I would start the return process early.
    9C1CC9CE-BCA8-4423-9D77-377BE0A378F3.jpeg DF501C7E-3A36-4475-B383-CF83661BB230.jpeg
    Pulse07 and Kasra like this.
  10. Pulse07
    Pulse07 Active Member
    273
    140
    East Bay, California
    2020 Prius
    XLE AWD-e
    Make sure to use a K&N drop in filter, 93 octane, use B mode only, and an amazon turbo generator. /S
    Drakxyfly likes this.
  11. Pulse07
    273
    140
    2020 Prius
    XLE AWD-e
  12. Branchingout3
    Pine City, Mn
    2022 Prius
    I can't say if it's a scam or not, I put it in during colder weather when my snow tires were still on. That always lowers my MPG. however, this summer I have been averaging 53 MPG with a high of 58.5 MPG. I drive almost all highway. I don't know what you all get, but I am pretty happy with this. I am running Bridgestone Ecopia, the same tires that came on the vehicle. Power is good. Better? Maybe, but not noticeable.
  13. Branchingout3
    Pine City, Mn
    2022 Prius
    I just stuck on a Scat Pack sticker. I got 50 visual horsepower immediately.
    Drakxyfly and Pulse07 like this.
  14. Drakxyfly
    Drakxyfly Member
    119
    29
    Usa
    2021 Prius
    Anyone that knows anything about tuning vehicles knows that all of these one size fits all/obdii tuning boxes are scams period. You simply can't tune a modern vehicle that way it's not possible. The ecu is too complex to be altered in that fashion. Changing the iats does nothing if your not compensating with fuel to take advantage and of the denser charge of air except create a dangerous situation. Like in this case running lean and causing your engine to go boom. So to protect the car in these cases the ecu will dump fuel to run the car rich and makes sure a leak condition doesn't occur. This causes worse fuel economy. The Toyota hybrid system vehicles have also been known to have extremely secure security protocols built into the ecu. The ecu itself will only adjust so much before causing issues.
    V Sport Wagon likes this.
