Inop gas gauge 08 Prius
Discussion in 'Gen 2 Prius Technical Discussion' started by Jim Caldwell, Jul 25, 2024 at 11:14 AM.
  1. Jim Caldwell
    Jim Caldwell Member
    144
    26
    Mathis
    With car topped off, it constantly flashes the first " almost empty" bar. Im a pretty good sunday mechanic. I could probably change the bladder myself sucessfully. Hopefully there's a youtube video on how to do it. But where can I obtain a new one from, and what is the cost?
  2. Tombukt2
    Tombukt2 Senior Member
    9,201
    1,613
    Durham NC
    I don't think you can remove the bladder I'd like to see that YouTube video I don't think it's a replaceable part You wouldn't get a new one Toyota sells you a new tank The UK doesn't have the bladder might be prohibitive getting a tank in the evap canister and all that that hangs in behind the tank and above it from a UK car anybody ever does want to do this I'll go in with him I'd like to get one or two myself. But I'm thinking there's a tank already in the States that should be able to do this duty matrix Yaris something I just haven't had the time to really really look into it but the matrix rear sub frame is so close to our Prius generation too it's uncanny much of the suspension and all that can fit so the floor pan It's close to identical
  3. Brian1954
    Brian1954 Active Member
    836
    312
    South Central PA, USA
    Call your local Toyota parts department for a price. They are very expensive.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,232
    5,934
    Columbia, SC
    No, you can't.
    There is! But it's labelled as swapping fuel tanks, so find your nearest salvage yard with a gen 2 that doesn't puncture tanks as part of the yard prep and purchase the fuel tank. Install it in your car and call it a day. You can probably get it done for <$150.
    Of course, this assumes your problem is truly a failed sending unit.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,477
    1,584
    NJ-USA
    Assuming your Mathis is the one in Texas, then the fuel level sensor is part of the sealed fuel tank. This is true for all North American spec Gen2.
    There are no serviceable parts, you can only replace the complete tank assembly. That includes the bladder, fuel pump, filter, pressure regulator, and level sensor. (fairly $$$)
    If you're not part of the rust belt, then all of the vapor emissions plumbing on top of the tank can get reused.
    I would first confirm that the level sensor is open circuit. Pop out the rear seat base and the access panel underneath. Unplug the connector and use a multimeter to check resistance across the 2 sensor terminals (the brown and the black wires).
    #5 mr_guy_mann, Jul 25, 2024 at 12:47 PM
  6. mr_guy_mann
    3,477
    1,584
    NJ-USA
    Here's the connector. Normal range for the sensor is 4 - 110 ohms. prius%20tank%20conn.jpeg
