Insert DVD Navigation Disk
Discussion in 'Gen 3 Prius Main Forum' started by eglmainz, Jul 23, 2009.
  1. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    This morning, after parking for a few minutes to grab breakfast, upon returning to my car, when I went to 'Ready" mode, the Nav system complained briefly that no DVD disk was installed. For a second, I panicked, thinking someone may have broken in.
    As I started to look for the signs of forced entry that I felt I must have missed, the system started to load the DVD, and after a minute or so, did complete that load, and seemed to run fine after that.
    The odd thing is that I did not touch the DVD Navigation system. I was just starting that car, which was parked about 5 minutes. Prior to that, I was listening to XM when I pulled in, and did not touch the system at all when I arrived (parking or when returning).
    While it seems to have worked fine after that, it deleted the 'cookie crumb trail' that I was displaying on my map, and I could not locate that to turn it back on.
    Has anyone seen this before, in a 2010? In an older Gen2? Is this indicative of a larger potential issue? How do I get the 'cookie crumb trail' back?
  2. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    I once ejected the NAV DVD by accident from holding down the eject button for too long.
    As for the "cookie crumb trail," do you mean route trace? Maps > Show on Map > Route Trace.
  3. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    That's it... Thanks. I could not remember this morning. I understand if I was touching the Eject button, then it would have made sense.
    Instead, all I did was turn off the car and leave. When I returned, I simply sat down, and pressed 'Start'. Instead of the usual logo showing up on the NAV screen, I got the 'no DVD found' message, or whatever it said. A minute later, it loaded, and then ran fine. (but I never touched the Audio System at all! Odd.
  4. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    This morning, for the third time now (in two months), as I started the car, the NA screen says, "Please Insert Navigation DVD". The odd thing is that I have yet to eject the DVD disk, and have not done so once since owning the car!
    Has anyone had to wait for the Disk to load on it's own, without having ejected the DVD? When it does this, it also deletes many of the settings that I have on the NAV, such as defaulting to allow Toll Roads, and leaving the 'Cookie Crumb' trail on the map.
    Do I have something to worry about here? Anyone else getting the message for no apparent reason? Each time it has happened has been when starting the car, and each time that this has happened, it resolved itself within a minute or two. This is beginning to worry me.
  5. anniea
    anniea New Member
    59
    Atlanta
    Two days ago, this happened to me as well--I had to wait a minute while it told me the DVD was loading. As with you, it happened randomly when I started car.
  6. Randall Rash
    Randall Rash Member
    149
    25
    Rockwall, TX
    I would suspect a dirty DVD. Eject it and look for smudges on the bottom. Wipe it with your cotton shirt anyway and pop it back in.
  7. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    If this persists, keep a log of when it happens and take the car in - may be eligable for a head unit swap if the DVD isn't defective.
  8. Jabber
    Jabber Chicagoland Prius Guy
    703
    213
    Chicago
    This is the first time I am hearing this problem on a gen 3. Eric, pop out the nav disk and make sure there isn't some type of dust on it. If it continues to happen, bring it in to one of the local dealers and have them make a note of it on toyota's system.
  9. mccats
    mccats New Member
    44
    Midwest USA
    Never had a problem. Had the system on our old 2007 Camry also.
    I would pop it out and see if the installer got a hair or lint on the disk or it looks like there is a scratch on it or dirty.
    If that doesn't work, I'd call the dealer and see if they could swap out the disk with another car or order you a replacement.
  10. daveelt
    daveelt New Member
    17
    Las Vegas, NV
    I just got my Prius about 10 days ago and am loving it. Had a Charger RT before, go figure.
    I am having this problem with my Nav unit. Did your go away or did you have it fixed?
    Thanks
  11. Hfxbouy
    Hfxbouy New Member
    KC MO
    Just had the same problem with mine. Never had it out before.
    Took it iut and claened it seems fine but will log it here so I can go back if it happens again. Maybe dust is getting in somehow?
    I do load CDs often as son borrows can and brings his music!
  12. daveelt
    daveelt New Member
    17
    Las Vegas, NV
    I don't load CD's often and it has happen on 3 mornings now. Thing I will have to take to Toyo, but should log first since it is intermitant and may not be happening when I take it in. I have even tried to eject the disk when it is happening and it just says there is not disk in there.....weird.
  13. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    As I was at my dealership this week (it's over an hour away), and I met with the "Master Service Manager". He opened a case for me, and is going to contact Toyota and get back to me. He stated that something similar has occurred from time to time, and in the past what was needed was a new disk (which he stated would be provided if this is the determination), and a system reset. He claimed that this has fixed several over the years, and in one stubborn case, and new NAVI system was installed, again under warranty.
    So, the short answer is No, it's not fixed yet, but I am confident it will be resolved in short order.
  14. garygid
    garygid Senior Member - Blizzard Pearl
    379
    23
    Orange County, CA
    I have had my NavDVD out 3 times to look at things on the disc label, but no problems.
    Handle ONLY by edges and the center hole.
    Do NOT touch the surface (as is often done in the movies).
    Poor reading is often a dirty read lens (if not a dirty disc).
  15. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    Re: Insert DVD Navigation Disk -- me too
    The same thing happened to me when I started up the car this morning. I got the message to load the Nav DVD. I couldn't change to any other screen display and couldn't figure out what to do. I pressed the CD Eject button but that just opens the changer -- I didn't know how to eject it because there was no screen asking me to eject. I seemed to remember that you change the DVD by going through the INFO screen, but that wouldn't come on. I was in a hurry to get to work and didn't have time to look anything up. I held down the INFO button for a while and eventually the system rebooted itself and all was well.
  16. garygid
    379
    23
    Orange County, CA
    To eject the NavDVD, hold down the Eject button for about 5 seconds, I think.
    Or, more normally, Info button, then the on-screen Maps, and on-screen Eject.
  17. PriusRos
    1,973
    218
    Rockville, MD
    This happened to me two more times. The first time, it decided to reboot itself after a few seconds so I thought I could live with that. Maybe I don't have to do anything and it will reboot.
    This morning, however, the message came on and stayed there. Nothing I pressed seemed to get it to reboot. The screen display did not change. I didn't have time to fiddle with it. I tried holding down the eject button but nothing happened except that it just lifts the screen and exposes the slots. I continued to hold, nothing happens. If I stop holding the eject button, and then touch it again, it just closes the screen. The message is still there. I think the 5-second rule is when you are actually ejecting CDs (after selecting to do so from the screen), if you hold down the eject button it will eject the CDs including the nav.
    This is really annoying.
  18. PriusRos
    1,973
    218
    Rockville, MD
    Has it been resolved?
  19. daveelt
    daveelt New Member
    17
    Las Vegas, NV
    I could be crazy here....but the problem had gone away and is back the last couple of mornings....since it turned chillier again!
    Am I nuts or could this be related to temperature? Anyone in the colder areas have this problem?
  20. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    Not yet. I am bringing into the dealership within the next week or so (I have also just passed the 15k mark, so time for an Oil change).
    They told me that all they would be doing the first time I have this issue looked at, is to remove it, make note of some serial information, and run a diagnostic. After that, they will get more information from Toyota, and hope to help me with this.
    It has happened one more time now, and each time for me, it has resolved itself, but once. That time, I needed to turn the car off and back on, at which time, it reloaded slowly, but did reload.
    I'll update here once I see them.
