inside chemical smell
Discussion in 'Gen 3 Prius Main Forum' started by cobradb, Sep 11, 2010.
  1. cobradb
    cobradb Member
    105
    tn
    the only disappointment with the 2010 prius is the terrible chem smell in side the car,, after six months it hasnt changed... in fact it is B.S. and doesnt seem healthy even running with outside air
  2. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    It has little or no "new car smell" so I have no idea what you're talking about.
  3. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    As did the previous post, many people have commented, some with disappointment, that a new Prius doesn't even have a new car smell. You'd better get a dealer to check out your chemical smell.
  4. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Mine had the new car smell, still has a faint whiff! Certainly not an unpleasant chemical odor!
  5. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Our car had minimal new car smell and it dissipated quickly.
    The all weather mats were a different story. When I took them out of their plastic covers, they smelled so bad that I wouldn't have them in the car. I was going to return them but after leaving them in the garage for a month, after a month of warm (for Victoria) weather, the smell had reduced to an acceptable (low) level and that went away in a reasonable time.
  6. Colonel Ronson
    Colonel Ronson New Member
    443
    33
    Tucson, AZ
    There was a new car smell for me, but it wasn't as strong as previous new cars i've been inside.
  7. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    Mine also had a "urea" odor that came from the AC vents. My guess was the plastic had a bad smell used in the venting system. I did solve it by purchasing a product called "Little Trees" New Car Scent.
    Here's what I did:
    I took out the cabin air filter and placed a "little tree" on top of it. Then I replaced the filter. I got a nice fresh scent thru the AC vents. Eventually, my "urea" odor went away. Unfortunately, the "little tree" only lasts about a month.
