Inside rear hatch cover
Discussion in 'Gen 2 Prius Main Forum' started by bogeybob513, Jul 9, 2013.
  1. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    I inadvertently pulled down too hard on the hatch cover when trying to close it. Now I can't seem to get it to adhere to its fasteners. Has anyone any experience with how to re-fasten the cover?
  2. Patrick Wong
    18,200
    6,479
    There are ~11 blue plastic fasteners which all need to be attached to the cover. If any are stuck to the hatch sheet metal, pull them out and reattach to the cover.
    Then put the plastic cover in place and hit the plastic cover where each fastener is located. The fastener will pop into the mating hole in the hatch sheet metal.
  3. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    Thanks Patrick, I'll give it a go.
  4. theshark
    theshark Member
    164
    Martinsburg, WV
    On very hot days, I cannot open my hatch back. So the entire summer it's useless.
  5. Patrick Wong
    18,200
    6,479
    If you care to figure that out, the problem is either electrical (a faulty switch or solenoid lock actuator) or mechanical (hatch lock might need adjustment.) I'm sure the problem can be identified by your dealer if you do not care to work on the problem yourself.
  6. theshark
    theshark Member
    164
    Martinsburg, WV
    It's the "rubber" handle. It melts and is toooo hot to touch.
