Install dash light to show when ICE is on / off ?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by cDxA, Feb 2, 2026 at 2:54 PM.
  1. cDxA
    cDxA Junior Member
    40
    Imagine an LED that comes on when the ICE does.
    Install it in front of you on the dash.
    Just bright enough to not be distracting.
    Why not just look at the screen ?
    Well, because I like to focus on driving instead of the screen.
    My screen is also all clouded up and cracking inside.
    How hard would it be to find the wire going to the ICE that is powered on and off and splice into that with a low wattage LED ?
    Could that brick the car ? Also, as with everything, it's never that easy.
  2. ChapmanF
    18,379
    well, that depends on whether there is such a wire
  3. Brian1954
    Brian1954 Senior Member
    2,329
    925
    South Central PA, USA
  4. PriusCamper
    PriusCamper Senior Member
    12,926
    5,251
    Pacific Northwest, USA
    Monitoring your engine RPMs via an OBD2 reader and an app on your phone will give you lots more info about your engine running or not then a light will.
  5. fuzzy1
    10,546
    Imagine an ODBII-port tachometer.
    As mentioned by a previous member, most of these devices supply plenty of other datapoints too.
  6. cDxA
    cDxA Junior Member
    40
    Thanks.
    I know these supply lots of useful data, but what I am needing is a way to look straight ahead at the road and know if the car is in ICE or not simply by seeing a light in my pereferal vision.
  7. dolj
    dolj Senior Member
    8,475
    4,300
    Wellington, New Zealand
    Why?
    What benefit do you perceive you will get from having this information?
    Brian1954 likes this.
  8. PriusCamper
    12,926
    5,251
    Many apps like "Car Scanner ELM" have a heads up display setting so your phone will reflect the screen on your windshield so you can look straight ahead at the road while keeping your RPM at 3500, which is the most efficient RPM to use when climbing mountains and doing freeway driving.
