Install LED low beam and high beam
Discussion in 'Prius v Technical Discussion' started by reidfm, Feb 22, 2023.
  1. reidfm
    reidfm Junior Member
    Bishop, CA
    Has anybody installed the new style LED bulbs in Prius v?
    I have a wonderful 2012, and have purchased from Amazon the
    Q36-H11 LED (Oxilam) low beam.
    Newest lamps are supposed to install directly without electric wire pigtails or glue-in bracket.
    Intend to order the Oxilam 9005/H9 LED (HB3) for high beams.
    Anybody with experience or comments welcome to give me suggestions????
  2. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    LED capsules tend to work well with projector lens housings, much better light output pattern control than with reflector housings. We use LED high beams and they complement the OEM LED low beams in the v Five.
    reidfm likes this.
  3. ChapmanF
    15,615
    If the v is like the liftback, it uses projector lenses for the low beams, but just reflectors for the high beams.
    reidfm likes this.
  4. Air_Boss
    3,952
    1,083
    New Yawk
    The 2012 v Five has projector optics for both high (OEM halogen) and low (OEM LED).
    reidfm likes this.
  5. TheTewks
    TheTewks Junior Member
    39
    United States
    2015 Prius v wagon
    I have a 2015 and the high beams run at 50% and are my DRL's during the day by default (base model two trim) and those plug in LED replacement bulbs DO NOT like being run at 50% and likely will fail immediately or flicker crazy, or just not light, or something else weird.
