Install louder horn and separate button on the steering wheel
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Troy DIY, Sep 13, 2023.
  1. Troy DIY
    Troy DIY New Member
    Fort Lauderdale FL
    This is my first post and I have learned much over the past few months here.
    The 2007 Prius horn is wimpy and I bought a high low air horn to add and not to replace the existing one. I could install a momentary switch on the dash panel but want to have quick access to the button. My steering wheel controls has an empty section because I don’t have the navigation and handsfree phone option. I recently replaced the clock spring and realize there are unused path ways.
    Are there diagrams that shows the wheel side and column side pin outs for the connectors? If none exists then I’ll use a multimeter to test for open unused pathways.
    Thanks!
    douglasjre likes this.
    49,383
  3. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Welcome to PriusChat!!
    There are digital copies posted in the forum, and some members will host or send them as well. The advanced search feature works.
    Try this : https://priuschat.com/attachments/prius-wiring-pdf.33780/
    If you do test, please post anything learned.
    Please use this thread to document this mod so that others can learn, and include lots of pictures, as everyone loves those.
    FYI : you're moderated until you've posted 5 times.
  4. Primetime Paul
    Primetime Paul Junior Member
    31
    Tap into the existing horn connection with a 4 pin relay. I did this on my motorcycle with a Stebel Nautilus air horn. Works great and no codes.
    Pixel 7 Pro ?
  5. douglasjre
    douglasjre Senior Member
    1,858
    647
    Orlando, FL
    I've never had a horn prevent a collision but I like it. I want a train horn for mine
