Install motor speed meter
Discussion in 'Gen 2 Prius Main Forum' started by Huibin, Aug 19, 2008.
  1. Huibin
    Huibin Junior Member
    Beiijing
    I bought a motor speed meter (RMB 80 Yuan) from taobao (PRC version of Ebay) and successfully installed . The motor speed meter was mounted on the top of steering column.
    The idle run speed is 1300 RPM, maximum of motor is 5000 RPM and idling check is ranged from 1000-1200 RPM.
  2. Huibin
    Beiijing
    The pic.
  3. richard schumacher
    7,664
    1,043
    United States
    Nice installation. Does it connect to the CANbus to sense engine speed?
    May we ask, how much did you pay for the Prius?
  4. Huibin
    Beiijing
    The meter have five cables but only three of them need to be connected to the diagnose port under the steering wheel.
    No.4 pin for Ground (GND)
    No.9 pin for sensing the motor speed
    No.16 pin for power
    The cost for purchasing Prius is still a pain for me. The basis price is 250K RMB and VAT is about 21k RMB. The price is a pretty high.
      File size:
      20.7 KB
      753
  5. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    And how much did you pay for the "motor speed meter". Does it display any other gauges as well? Just wondering how it compares to ScanGauge as far as cost, features, and easy of installation.
  6. Danny Hamilton
    926
    94
    Translation, as a favor to those who are familliar with U.S. Dollars:
    The cost for purchasing Prius is still a pain for me. The basis price is $36,416 and VAT is about $3,059.
  7. Huibin
    Beiijing
    It only displays the RPM of the gasoline engine. The cost is around 12 USD and easy to install.
  8. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    In the interests of clarity, that is an -engine- speed meter, or tachometer. The motors are electric in the Prius. ;)
    You will find the engine will idle all the way down to 950 RPM or so, just before it stops if it isn't needed.
