Install Relay Harness for HID conversion?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ajc, Feb 18, 2010.
  1. ajc
    ajc Member
    340
    38
    pa
    I just received my HID digital kit with a Relay Harness + 50W resisters. Do I have to use the Harness on my 2010 Prius III?
  2. ePrius
    ePrius Member
    162
    76
    I used the relay harness on my HID kit.
  3. ajc
    ajc Member
    340
    38
    pa
    Did you connect the + directly to the battery or did you use the + terminal in the fuse box?
  4. ePrius
    ePrius Member
    162
    76
    I used the + terminal in the fuse box.
  5. ajc
    ajc Member
    340
    38
    pa
    Do I need the Relay Harness with the 50W Resisters?
  6. ePrius
    ePrius Member
    162
    76
    My relay kit came with the resistors.
    Basically for my setup, I ran the power cable (red) from the HID kit to the + fuse within the fuse box. Then I connected the my relay kit which consists of ground wire (black) and resistors to the HID kit. The ground wire (black) are held by bolts to the car frame.
