Installation FIAMM EL GRANDE 74100 HORN Gen 4 Prius + VID SOUND
Discussion in 'Gen 4 Prius Accessories and Modifications' started by NguyenCB7, Sep 4, 2016.
Tags:
  1. NguyenCB7
    NguyenCB7 Member
    71
    67
    Fullerton,ca
    Sup Guys! I decided to upgrade the horn to a better one. Bought the FIAMM EL GRANDE 74100 for 20 bucks on Amazon. Install is REALLY plug and play, took about 10 Mins. You will need a Socket Wrench 10mm and thats it. Here how I did it on my 2016 Prius 3 with Advance Tech Package.
    ENJOY!
    10MM socket
    Push clip? (IDK the real term) locations
    Push middle inward to unlock
    Horn Location
    Driver Side: Disconnect factory plug and unbolt bottom nut.
    Passenger Side
    Use the FIAMM NUT to put on the new Horn
    20160903_223855.jpg 20160903_215301.jpg 20160903_215308.jpg 20160903_224042.jpg 20160903_224012.jpg
    Only used the nuts for the kit.
    reinstall cover and lock push clips
    And ALL DONE!!! GOOD LUCK AND KEEP ON MODDING!!
    Heres a Video on how it sounds now.
    #1 NguyenCB7, Sep 4, 2016
    Ryder99, JLX, emmbec and 13 others like this.
  2. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Looks pretty easy.... unless I can't fit my hand down in there, or I break a clip trying to reinsert it. :LOL:
  3. booke02
    booke02 Active Member
    391
    415
    Israel
    Plenty of room for your hand - it is surprisingly roomy down there
    Coast Cruiser likes this.
  4. Coast Cruiser
    2,267
    2,571
    Thanks booke. I will give it a try. When it comes to mechanical things, I'm like a "bull in a china shop!":ROFLMAO:
    glennonrp and booke02 like this.
  5. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    I may give it a try in about 20 degrees which is probably only a couple months from now.
  6. Coast Cruiser
    2,267
    2,571
    See the air filter box in the upper right corner? Maybe someone can post a video on how to open that. Mine won't move.
  7. NguyenCB7
    NguyenCB7 Member
    71
    67
    Fullerton,ca
    Why do you want to open that?
  8. Coast Cruiser
    2,267
    2,571
    Just practicing, for when it's time to replace the air filter.
    When I unhook the two clips, I can't get it open. I guess there are some hoses you have to loosen or remove?
    krmcg likes this.
  9. NguyenCB7
    NguyenCB7 Member
    71
    67
    Fullerton,ca
    Haven't tried but from previous experience with other cars, you are right. You might have to loosen up the hose clamp that is attached to the air box. I'll take a look tonight.
    Terre, RCO and Coast Cruiser like this.
  10. Owll
    Owll Junior Member
    San Diego
    Un-clip both of the latches on the right of the lid. Lift up on the right side a little, while also moving the lid to the right. The left side of the lid is actually held in place by u-shaped moldings on the bottom of the air box. It just slides out.
    That being said, there's "just" enough room to swap the air filter, without removing hoses / hose clamps. It's tight, but it can be done.
  11. Coast Cruiser
    2,267
    2,571
    Thanks very much.
  12. Owll
    Owll Junior Member
    San Diego
    You are very welcome.
  13. krmcg
    2,592
    2,390
    Whittier, CA
    I <3 my upgraded horn.
    Terre, TheRedRocker and NguyenCB7 like this.
  14. RCO
    RCO Senior Member
    3,709
    5,183
    Cornwall
    Sounds like you had a personal dilemma beforehand.........
  15. krmcg
    2,592
    2,390
    Whittier, CA
    Not really. Good to better.
  16. Coast Cruiser
    2,267
    2,571
    What am I missing...
  17. Coast Cruiser
    2,267
    2,571
  18. krmcg
    2,592
    2,390
    Whittier, CA
    Just a little volume.
  19. Coast Cruiser
    2,267
    2,571
    Why is it, that auto manufactures always seem to put a "beep" horn on smaller cars/economy cars. Just to save money? I want a this! :ROFLMAO:
  20. Owll
    Owll Junior Member
    San Diego
    Oh my........I could get in sooooo much trouble..........
