Installed aftermarket radio. Now panel lights are stuck in "day" mode.
Discussion in 'Gen 2 Prius Main Forum' started by QuillBin, Oct 5, 2015.
  1. QuillBin
    QuillBin Junior Member
    West Chester, PA
    I think I ran over a bump and something shorted out. Now the panel lights on the MFD Flicker on and off as if I was turning the headlights on and off ( the headlights remain on however) My cheap solution is just leave the dimmer switch in the all the way to the top position. MFD works. Everything else works. It's just the lights are weird on the MFD. Did the MFD cat fried or did something else get fried? Either way it should just be a salvage parts swap should I need to replace anything?
    48,987
    could just be the dimmer switch.
    QuillBin likes this.
  3. frodoz737
    frodoz737 Top Wrench
    4,297
    2,347
    33
    Aftermarket on the Gen III had the option to splice into the dimmer wire for the head unit. If yours was similar, check your splice.
  4. QuillBin
    West Chester, PA
    Where could I purchase a dimmer switch? And I am shocked that this incredibly complicated car electronics wise has such an evidently simple control system for the button lights on the mfd.
    #4 QuillBin, Oct 5, 2015
  5. QuillBin
    West Chester, PA
    Replaced the dimmer switch. No change. What else controls the dimmer circuit?
  6. bisco
    48,987
    bummer. if no one knows, i guess you'll have to go to toyota tech info and look at the schematic.
  7. jdenenberg
    jdenenberg EE Professor
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Send me a PM and I will send you a link to the maintenance manual on my web server for your Prius. One of the PDFs contains the wiring diagram (very complex).
    JeffD
