Installed NewPriusBatteries and got P0A80 again
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Berch1943, Jun 8, 2020.
  1. Berch1943
    Berch1943 Member
    146
    Arizona
    I just replaced the HV battery from NewPriusBatteries.com . Took it for a test drive, and I got the same error P0A80 and P3023 . What is strange is that with my old battery I had the exact same error P3023, is that a coincidence? I tried clearing the codes and taking for a test drive , but after a while it comes back. I don't know what to do, please help!
    I did a screen recording of Torque Pro so you can judge the readings yourself. At 2:13 in the video you can hear the Warning Light come on and the fan starts going.
    #1 Berch1943, Jun 8, 2020
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,970
    4,713
    Texas Hill Country
    I am sure you did the 12v battery disconnect to reset codes. I assume you rebuilt the battery with new modules, buss bars, wiring harness, and interconnects from the supplier. If you did not replace one of those parts that could be the issue especially the wiring harness. Each module is being monitored for voltage by the battery ecu so if everything else is new and mounted correctly, then the ecu analog input for module 13 may be bad. I would certainly call the supplier and get their input.
    jerrymildred likes this.
  3. Berch1943
    Berch1943 Member
    146
    Arizona
    I pulled out the ECU , checked the pins and connectors. They both looked fined to me.
    #3 Berch1943, Jun 9, 2020
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The part that goes bad in the ECU is not visible in the images you provided. Usually whiskers grow on the backside of the connector over time. Sometimes they jiggle free, sometimes they don't. The connector can burn but so can the copper traces depending on what's going on inside. Sometimes it is visible, sometimes it is not.
    You can see the far bottom trace on this ECU is burnt and not working. Connector looks fine. This ECU will always log a fault for that block because the analog input is destroyed.
    audiodave likes this.
  5. rjparker
    7,970
    4,713
    Texas Hill Country
    Pretty clear that module 13 is being read incorrectly. See pics at time 51 and 105 from your video. It should not be off by that much. Could be a loose connection in the harness itself but my money is on the ecu, perhaps the problem from the beginning.
    Here is a snapshot of my battery back in April using the Car Scanner app. Note the "difference between maximum and minimum voltage" is only 0.07 volts.
    #5 rjparker, Jun 9, 2020
  6. Berch1943
    Berch1943 Member
    146
    Arizona
    I opened the ECU and the circuit board seemed like it was in good condition. I could not find the whiskers as you mentioned. Which is the connecter for block 13?
    20200609_072918.jpeg 20200609_072940.jpeg 20200609_072946.jpeg 20200609_072954.jpeg 20200609_073000.jpeg
    #6 Berch1943, Jun 9, 2020
  7. rjparker
    7,970
    4,713
    Texas Hill Country
    Check my post above. Clearly your monitoring is at fault. You could get some electronics cleaner spray and go over the ecu board but your best bet is likely the harness or the ecu. A junkyard or ebay could provide either.
  8. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    To be clear, the harness is brand new with our kits. This, coupled with the same error before and after installation, points to ECU.
    Not all ECU damage is immediately or ever visually apparent.
  9. Berch1943
    Berch1943 Member
    146
    Arizona
    I've ordered a used ECU off ebay. I'll see how it goes. I'll update back in a week.
    edthefox5 and bisco like this.
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Looks very clean I see little bit of schmutz around the crystal 703 but pretty clean. Its led a nice life. If it hit my bench first thing I would look at is the ESR of those electrolytic's I have an original Dick Smith kit meter thats how old I am lol.Still works great. I don't see any puffy's though. You probably have a semiconductor failure there.
    Its unlikely the new battery would throw the same code if that makes you feel any better. I know its been alot of work so far.
    Berch1943 likes this.
  11. rjparker
    7,970
    4,713
    Texas Hill Country
    It appears the a/d or the analog mux was throwing in an integer bit plus or minus. Battery Block 13 went from 14.6 to 13.6 while the rest remained close to 14.6 and another time block 13 went from 16.1 to 17.1 vdc while the rest hovered around 16.1. Which corresponds to code P3023.
  12. Berch1943
    Berch1943 Member
    146
    Arizona
    I’ve got my replacement ECU and........ same thing. Took it for a drive , got P08A0 and P3023 again. So I think it must either be one of 2 things:
    1. The battery is bad.
    2. I installed something wrong.
  13. AzusaPrius
    AzusaPrius Senior Member
    1,877
    822
    You just need to test the voltages of each cell module. Take all the bus bars off and do that then you will see which one is lowest and replace any in the 6 volt range.
    edthefox5 likes this.
  14. Berch1943
    Berch1943 Member
    146
    Arizona
    I think I found the problem. The jumper bolts around module 13 were loose. I somehow forgotten to tighten them. Went for a test drive, no errors. Bars stayed green throughout. Hopefully that was it, only time will tell. So I guess it's safe to reuse my old ECU then?
    #14 Berch1943, Jun 12, 2020
    AzusaPrius likes this.
  15. rjparker
    7,970
    4,713
    Texas Hill Country
    I would go back to the original ecu as a double check. Odd it was the same on your old modules unless things were loose back then or messed with before. Is it a hard module to get adequate access to #13?
  16. edthefox5
    10,096
    4,806
    Clearwater, Florida
    P3023 is Battery Block 13 weak which the ECU will probably run home to mama and condemn the whole pack so i think you got it. The ecu should be fine.
    Don't feel bad we see this hundreds of times people rebuild there battery's and forget to to take the make sure there all tight tour of all the connectors.
    But...are you sure the sensors didn't have rotten ends hiding under there connectors which is a very common problem too. Corrosion likes to run up a wire. Mainly because it has no where else to go. You have to pull the wire coating back a little and see if theirs any green in there.
    But good luck though.
    #16 edthefox5, Jun 12, 2020
  17. rjparker
    7,970
    4,713
    Texas Hill Country
    He has new modules, buss bars and harness.
