Installing an oem backup camera on a 2005
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Miguel Olivares, Dec 24, 2016.
  1. Miguel Olivares
    Miguel Olivares Junior Member
    56
    Oakland
    Is it as simple as connecting
    The harness in the hatch and adjusting the camera so that it points correctly downward?
  2. JC91006
    16,673
    8,518
    No, it's not as simple as you've described
  3. Miguel Olivares
    56
    Oakland
    Ahh thank you. Any tips on maybe finding a guide online?ive exhausted my searches
  4. JC91006
    16,673
    8,518
    You would need to sell the 2005 and buy a 2006
  5. OBJUAN
    OBJUAN Member
    165
    76
    canada
    Any luck?
    JC91006 is too skeptical...
    I just installed (today) the 86110-47210 MFD into my base 05, replacing the original "47080 MFD".
    ITbland's M13 pin out data was perfect, re attached. The big wires came out easy but the violet
    on pin 25 was stubborn. I used a very fine jewellers screw driver. Make sure
    the locking bar is out, then push the screw driver firmly into the hole closest to the
    edge and it will pop. Then you can pull out the violet wire. I'm still sorting out the REV+
    line for pin 21....
    I've ordered some shielded 3 core cable from aliexpress for the camera feed.
    Still figuring out the mount since there is no factory hole in the hatch for the camera.
    It's aluminum so magnets won't help to hold it in place. A picture, with minimal parallax,
    of a hatch showing the camera hole and the two holes near it for mounting the plastic trim
    that holds the backup lights and door lock release would be a great help to make a template.....
