Installing CarPlay / Android Auto stereo in Prius Prime Plus
Discussion in 'Prime Audio, Electronics, and Infotainment' started by dcantat, May 24, 2019.
  1. dcantat
    dcantat Junior Member
    31
    2018 Prius Prime
    Let me start off by saying this went easier than I expected. I do have experience in soldering and minor electric work but that was the only technical aspect, and this was straight forward and easy. I have completed this process and can assure you this works. Oh and if you need to check if parts are compatible with your Prius Prime Plus, just leave off the prime part and calls it a regular Toyota Prius.
    Parts list:
    Pioneer w4400nex stereo
    Metra Mounting Kit (kit to adapt opening to standard double din)
    Maestro RR main unit (this makes your steering wheel and other features work with the new radio)
    Metra 40-LX11 Antenna Adaptor (if you ever want to listen to the radio again)
    USB Port Retention Cable ( makes the port in the center console keep working)
    Maestro HRN-RR-TO2 Plug and Play T-Harness for TO2 Toyota Vehicles ( connects everything together)
    Optional
    Parking Brake Bypass Video in Motion Interface Module ( this only matters if you want the same features to work when parked as when driving, technically not legal)
    I'll continue in the reply with steps and photos, have to get dinner now and there is no way to save in progress.
    Teaser pic:
  2. Salamander_King
    Salamander_King Senior Member
    10,975
    8,873
    New England
    I am guessing the swap only works for Plus model with the small head unit. Do you know if there is any option for the large 11.6 inch display swap?
  3. dcantat
    31
    2018 Prius Prime
    I know nothing of that car, Plus only here.
    Salamander_King likes this.
  4. dcantat
    31
    2018 Prius Prime
    Step 1.
    Remove the black plastic trim. This can by done with strong hands or careful usage of panel removal tools. I began on the bottom corner near the start button and worked carefully along the bottom edge then pulled up. See photos for further reference of pressure based clips. No screws or twists of any kind hold this on.
    Where the passenger side separates.
    Where the top separates
    Backside once removed.
    After the trim is unclipped there are three electrical connectors to remove and one twist mount that just holds wires in place.
    This is one of the steps that had me the most concerned because I knew if this went poorly the project would be stalled until I could replace the trim. Also I didn't know what wires were connected to the trim.
  5. kellyj
    kellyj Junior Member
    43
    Orlando, fl
    2019 Prius
    Thanks for this! I just bought a 2019 Prius xle and plan on doing something similar asap, How well does the head unit work with wireless android auto? Would you recommend it? Thanks!
  6. kellyj
    43
    Orlando, fl
    2019 Prius
    Also hows the head unit amp and factory speakers sound or did you do any speaker or amp upgrades? Thanks!
  7. will the engineer
    will the engineer Active Member
    238
    119
    LA
    2019 Prius Prime
    wth is a prius xle?
  8. will the engineer
    238
    119
    LA
    2019 Prius Prime
    following this thread because I want to do this
  9. Prius from Dad
    Prius from Dad Senior Member
    724
    1,115
    Toms River, NJ USA
    XLE is the new designation for Premium. LE is Plus and Limited is Advanced.
  10. kellyj
    43
    Orlando, fl
    2019 Prius
    to my knowledge and without looking it up - toyota has renamed the prius trim levels for 2019 to match the remainder of its fleet - thus prius, prius le, prius xle, prius limited. instead of I,II,III,IV
  11. will the engineer
    238
    119
    LA
    2019 Prius Prime
    baby steps! standrized their trim level names...now if toyota could only make their hybirds more "normal" looking
  12. TDIPWR
    TDIPWR Junior Member
    Asheville, NC
    Thanks for sharing, would you mind sharing the rest of the install guide? Or is it just that straight forward? Do you lose any stock features that we might miss? I am very interested in doing this.
  13. kellyj
    43
    Orlando, fl
    2019 Prius
    I just had this kenwood dmx905s installed - liked it because it had the features I wanted (android auto - wireless coming soon hopefully), capacitive touch screen and felt it matched the piano black dash as it has large glass front and glossy buttons. Start up fast a d so far I am very happy with the sound improvement and overall functionality.
    TDIPWR likes this.
  14. kellyj
    43
    Orlando, fl
    2019 Prius
    Btw I paid $150 for the install not including parts.
  15. Jamesb93612
    Jamesb93612 Member
    133
    69
    Clovis, Ca
    #15 Jamesb93612, Aug 8, 2019
  16. evpv
    evpv Active Member
    689
    337
    West Coast
    2019 Prius Prime
    Looks like it's a new product that hasn't been released to the public yet.
  17. TDIPWR
    Asheville, NC
    Have you missed any of the functionality of the stock unit? Looks like it fits in well overall.
  18. kellyj
    43
    Orlando, fl
    2019 Prius
    Haven't missed anything, seems like everything is available on other screen. I am extremely happy with the install and functionality...
    It is a huge improvement to say the least!
  19. etdweasel
    etdweasel Junior Member
    Curious how you access the touchscreen-based settings that were only accessible from the OEM head unit?
