Installing rear view mirror back up camera and fake alarm led
Discussion in 'Prius c Accessories and Modifications' started by rock88, Aug 13, 2013.
  1. rock88
    rock88 New Member
    23
    i am planning to install 3 devices in my prius.
    A back up camera , back up sensor and a fake alarm.haha yes really
    The back up rear view mirror needs a the positive for a acc fuse and black ground , the fake alarm needs a constant power and a acc power source
    I guess the back up sensor would be connected to the reverse light.
    1)Anyways , since this is a hybrid i dont know if i need to disconnect battery before using fuse taps on the fuse box, and if i disconnect the battery would i need to do something to reset the car.sometime when you take disconnect battery the car wont start , with hybrid i dont know. Or if disconnected just reconnect and everything should be good.
    2) what are good examples of acc fuse , power that only when the car is turned to acc or ignition.
    3)what is good choices for constant power , like hazard lights, dome lights , radio (maybe) . just want to know so i can use a fuse tap to those fuses. and after that i wont be able to put the cover back on , and if thats ok.
    thanks
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Moved to the proper sub forum
    ztanos likes this.
  3. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    You can disconnect the negative on the battery with no issues.
  4. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    nice list of future install. what type of mirror are you getting?
