Installing the Service Safety Plug Help
Discussion in 'Gen 2 Prius Main Forum' started by Elisa daSilva, Jul 15, 2022.
  1. Elisa daSilva
    Elisa daSilva Junior Member
    66
    17
    Biloxi
    I’ve searched the forum and internet, but can’t find a consistent answer.
    My hybrid battery was recently reconditioned but still won’t start. I found the service safety plug sitting on the side of the trunk.
    What is the proper procedure to stick it back in: with gloves or without? I see multiple videos of people doing it without but at the end, they slap on some text ALWAYS WEAR GLOVES even though they aren’t wearing any in the video.
    I know the 12 V battery should be disconnected but that’s all I know.
    The hybrid battery has been sitting over a month disconnected from the safety switch.
    Please advise and if you recommend the gloves, where’s the cheapest place to purchase them??
  2. Mendel Leisk
    40,584
    My first thought is "who did the conditioning, how on earth did they forget the plug, and should they come back and make it right? Oh and maybe do a test drive or something??".
    That aside, see attached:
    Fred_H, bisco and SFO like this.
  3. Elisa daSilva
    66
    17
    Biloxi
    Yes. I’m not going to say it was on purpose but yeah. So I’m not asking him to do anything else.
    When he installed it, he told me to try and turn it on. All the lights etc came on but it would go in gear. Then he said it must be the ECM and he’s come back with one BS.
    After looking up what it could be, I found the info about the switch and found it in the trunk.
    QUOTE="Mendel Leisk, post: 3268033, member: 69191"]My first thought is "who did the conditioning, how on earth did they forget the plug, and should they come back and make it right? Oh and maybe do a test drive or something??".
    That aside, see attached:[/QUOTE]
  4. Elisa daSilva
    66
    17
    Biloxi
    It says to wear gloves when inspecting etc. I’m still not sure if I need gloves when sticking the switch into the already discharged HV battery with the 12 V disconnected.
    #4 Elisa daSilva, Jul 15, 2022
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    @Mendel Leisk's picture is worth a thousand words. You don't want to forget that third step of sliding the lever home.
    There is no need to wear gloves when installing the safety plug. You are not able to touch any high voltage conductors. Got to the 4-minute point in this video to see how it installs. The video shows the battery with the cover off of the end that has the relays, service plug, etc. and you can see that you're far from danger plus you'll have the cover in place and won't even be able to see the internals.
    Elisa daSilva likes this.
  6. Elisa daSilva
    66
    17
    Biloxi
    So, disconnect the 12 v negative, then positive. Insert the switch and make sure it’s flipped
    Up and slid down etc, then reconnect the 12v
    Positive, negative
    Then try to start the car?
  7. ChapmanF
    17,347
    No need to overcomplicate. No need to fuss with the 12 volt battery. You won't be live-plugging the service plug as long as the car isn't READY, and the car won't go READY with the service plug out.
    Just push it all the way in, click the handle over, done.
    Toyota does recommend gloving up before pulling or inserting the switch, probably just for that much extra insurance for a tech who never knows if the car had a kid in it who poured Diet Coke down the back seat and left a sticky conductive trail over the plug.
    You could find your own comfort zone anywhere from Jerry's "no need to wear gloves" to Toyota's full-on class 0 freshly tested certified gloves, or anywhere in between, like wearing some relatively nonconductive gloves you already own.
    It is definitely not the same level of risk as poking around inside the battery with the cover off.
  8. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Actually, the error code for a orange service plug not being plugged in doesn't self-clear once its triggered. So if you don't have an OBD2 or techstream to clear the error code the 12v battery disconnection is necessary to clear the code.
  9. ChapmanF
    17,347
    Good catch ... I had never noticed that. I do see that where the manual talks about removing and installing the service plug, it has steps to disconnect and reconnect the 12 volt. So I won't officially advise skipping those steps (though I might still, in a pinch, skip them myself ;)).
    If I were doing it, though, in a Gen 2, I would just unplug the cables at the little fuse block on the 12 V battery + terminal; faster than fussing at the − terminal with a wrench. Still, you have to reset all the same things later (auto windows, radio presets, etc.) after reconnecting; nothing changes there.
    I see that the Gen 2 manual says, for the P0A0D code, "If the safety devices are correctly reinstalled, it will resume the normal operation after the power source is supplied again." Which I could read a couple of ways, since the HV ECU has both an always-on "BATT" supply connection and a switched "IGSW" connection. A lot of codes will get rechecked if you just cycle IG power (with the power switch), but if they mean the B supply here, that would only recheck the code after unhooking/rehooking the 12V battery (or the fuse supplying the ECU, at least).
    I see that in the Gen 3 manual, they have clearer language for P0A0D. There, it says "If the safety devices are re-installed correctly, the system will return to normal when the power switch is turned on (IG)."
    I can't tell if that's a case of them just clarifying the wording for the Gen 3 edition, or actually changing how the code behaves, and there isn't a Gen 2 handy for me to go see for sure. :cautious:
    #9 ChapmanF, Jul 15, 2022
    Fred_H likes this.
  10. jerrymildred
    11,517
    14,137
    Tampa, FL
    I do usually wear mechanic's gloves though. But that's because I'm generally removing or inserting it while in the process of replacing the battery and there are lots of sharp edges. :D
    Fred_H and Elisa daSilva like this.
  11. PriusCamper
    12,064
    4,896
    Yeah...
    Yeah, that's what's awesome about Priuschat. Had it not been for a specific Prius I was working on at start of the week, I'd not of known that particular info. As in two heads are better than one... Or in the case of social media a few dozens blabbering crazies seeking to help but mostly fishing for as many likes as @bisco is almost as good as two heads are better than one.
  12. Tombukt2
    Tombukt2 Senior Member
    12,214
    2,155
    Durham NC
    Gloves or not won't make a big difference disconnecting the 12 volt I've never done that in the Gen 2 or 3 as many times as I've taken these batteries out that's interesting. What you will need to do is on the last step of inserting the plug you need to get some leverage behind slamming your finger down to lock that last sensor doodad into place so you insert the plug it slides in pulls in and you're ready to slide it down Don't just casually slide it down and think you've done something you need to slam it it should make a loud clack. If it doesn't and you have no display or the red triangle turn it off unready go back lift the thing up you don't have to pull it all the way out again and slam it down I'm not saying you need to hammer it with a hammer but you need to pull it down smartly.
  13. jerrymildred
    11,517
    14,137
    Tampa, FL
    "Smartly"being a couple pounds of pressure. All it takes is enough to overcome the little detent that holds it in place once it's latched. Just push till it moves and you feel the detent and then the hard stop.
    Fred_H likes this.
  14. Elisa daSilva
    66
    17
    Biloxi
    “plus you'll have the cover in place and won't even be able to see the internals.”
    ? Do I have to have the cover in place? I want to test if it works before going through the hassle of putting the cover back on.
  15. ChapmanF
    17,347
    Well, that's the kind of question that could get this kind of answer:
    First, it's worth looking at how Toyota designed that service plug and cover to work. There's that service plug, and then there's that separate orange thing that won't let the cover come off until you unlock it, using the removed service plug as a key. So, clearly, they built all that to ensure that most people will never be near a live battery with its cover off.
    So, does that mean you can't have a good reason for doing what they built it to make sure most people won't do?
    Well, maybe you can. It gets like the familiar label "no user-serviceable parts inside". Most people stay out, but maybe some unusually capable users can service the parts inside.
    But going into that territory calls for a careful conversation with yourself about whether that group includes you yet. Sometimes the answer sounds like "if I have to ask basic safety questions, maybe not yet", or it might sound like "are there some courses nearby (or online) I could take that would move me into that group", or something like that.
  16. Elisa daSilva
    66
    17
    Biloxi
    Yep. That’s why I’m asking. I wasn’t sure if I had made it clear that the cover is off so I thought that might be an important detail.
    I’ll definitely put it on before testing if that’s what you recommend.
    #16 Elisa daSilva, Jul 17, 2022
    Fred_H likes this.
  17. Tombukt2
    12,214
    2,155
    Durham NC
    Yes we had our cover off for about 5 days just to make sure I wouldn't bolt it all up to have to change the temp sensor or something this was a brand new battery from the dealer I just had the top cover off and then if I was going somewhere and had to carry something I just set the cover on top of the battery and go do what I had to do. Then when I was sure everything was good I put the cover back on properly I had broken the little orange plug thing that just got thrown away The big fusible plug of course you have to have and that's what we're discussing here. I didn't know that would be a problem running the thing around with the bus bars covered and the cells exposed but silly me would have made a cool video if it blew up or caught fire or something oh well.
  18. Fred_H
    Fred_H Misoversimplifier
    558
    481
    28
    Germany
    Yes, the swarm intelligence at PriusChat is truly awesome. (Not to be confused with "crowd intelligence" which is generally not as good as swarm intelligence.)
    By the way, do I recall correctly that there is some kind of fuse inside the service plug? So if it doesn't work with the service plug properly installed, its continuity should be checked?
  19. Tombukt2
    12,214
    2,155
    Durham NC
    Yeah I think it's $125 amp a fuse and you can buy them if you look hard enough I have a few here they say you have to buy the whole plug for I don't even know what 25 50 bucks who knows. I found a comparable fuse from a supply house it goes on some kind of a board or something but it fits right in the in the plug no problem
    Fred_H likes this.
