Instrument cluster/dash readout dead
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hybrid Hobo, May 14, 2022.
  1. Hybrid Hobo
    Hybrid Hobo Member
    199
    50
    New Jersey
    *UPDATE - Now the car will not turn off when the power button is pressed. If someone can explain why this is happening I'd appreciate it. I'm disabled, and not having my car working is very scary as I'm extremely dependent on it. Thanks
    Some of you have been following my journey and threads on here, as it pertains to my new (to me) Prius, which I bought at the beginning of this year, and mostly use for car camping.
    Just returned yesterday from a 4 week car camping trip, and this afternoon my instrument cluster went dead. This happened once about 2 weeks ago, but I simply shut the car, restarted it, and it worked fine again.
    Anywho, glad this happened when I was back home, and not on the road.
    Questions...
    Does anyone have any easy fixes...at least to get it working temporarily?
    Is it safe to drive the car without it (without damaging anything further)?
    Anyone know where to get good used one's my mechanic can install?
    Is this issue ONLY the instrument panel, or could there also be underlying causes as well?
    Other than the panel being out, car rides like a dream, and no other problems to report.
    I was supposed to head out on the open road again tomorrow for a few weeks, but it now appears I have mechanical work in my future :mad::cry:
    #1 Hybrid Hobo, May 14, 2022
    PriusCamper likes this.
  2. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Do you solder much? Or have a friend that solders? This problem is a faulty capacitor that needs to be replaced in your combination meter? It's a very inexpensive and easy repair if you're able to deal with the hassle of removing it from the dash on your own.
    The reason the car won't turn off is there's some such down sequences integrated into the combination meter that don't work when the capacitor fails to start up the meter. For the past year I've had this problem in my 2007 and it's still super intermittent so haven't bothered to fix it.
    But when it does act up I press and hold the power button till it shuts down. Usually this means pulling the key FOB out of the slot to complete the shut down sequence.
    And if you don't have a soldering option you can send it off to these folks:
    https://www.texashybridbatteries.com/prius-combination-meter-repair or just drive your car all the way to Dallas without the combination meter and get it fixed by them... The car is safe, but a bit more dangerous to drive because you don't know how much gas you have left or how fast you're going. Of course your OBD2 reader and many apps will give you your MPH.
    jerrymildred and Hybrid Hobo like this.
  3. Hybrid Hobo
    Hybrid Hobo Member
    199
    50
    New Jersey
    Thanks, PC!!! I found Nikki Delventhal's video online (love her channel), and she had the SAME issue I'm having. So I learned how to force shut the car by holding the power button off for 3 seconds...and then clicking it 2 more times. That makes me feel better!
    Now the BIG question...is it better to buy a quality used meter & have my mechanic install it, or send it to an outfit like you mentioned, or perhaps these guys? 2004 - 2009 Toyota Prius Instrument Cluster Panel Repair
    QUOTE="PriusCamper, post: 3251473, member: 87188"]Do you solder much? Or have a friend that solders? This problem is a faulty capacitor that needs to be replaced in your combination meter? It's a very inexpensive and easy repair if you're able to deal with the hassle of removing it from the dash on your own.
    https://www.texashybridbatteries.com/prius-combination-meter-repair or just drive your car all the way to Dallas without the combination meter and get it fixed by them... The car is safe, but a bit more dangerous to drive because you don't know how much gas you have left or how fast you're going. Of course your OBD2 reader and many apps will give you your MPH.[/QUOTE]
  4. PriusCamper
    12,064
    4,896
    If you're unable to remove the combination meter yourself and the mechanic is doing it... I'd ask the mechanic to simply replace to capacitor for you. If they don't solder boards then they probably have someone who does that for them. But I'd encourage them to learn how because this is a common problem with Prius and it's one of the easier first lessons in board soldering... Having that skill means mechanic has more ways to make some money. Here's a video about how to do it:
    Hybrid Hobo and jerrymildred like this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Texas Hybrids is great. They repair and return all the combo meters we replace where I work. But replacing the capacitor is pretty easy as soldering jobs go.
    When you take it out, be careful of the two middle air conditioner vent assemblies. They get very brittle. It's common for them to crack even when you try to be careful. In fact, I had one crumble like sugar candy. You have to be very gentle & patient with the old ones. The rest of the dash comes apart pretty easily.
    Hybrid Hobo and PriusCamper like this.
  6. Hybrid Hobo
    Hybrid Hobo Member
    199
    50
    New Jersey
    Thank you, Jerry. I have an AMAZING mechanic here in NJ, but I probably won't be able to get into him until at least Monday. Hopefully he knows how to solder, because I don't. I suffered a massive stroke 2 years ago and I'm lucky to still be able to hobble around (badly), so repairing anything big that needs to be taken apart - like a dashboard - is definitely beyond my ability.
    Assuming the mechanic can do this, will the fix be just as reliable as the repair company you guys mentioned?
    P.S. - When I was looking for replacement clusters, many websites mentioned a $300 core fee? I thought that was just for the battery?
    PriusCamper and jerrymildred like this.
  7. jerrymildred
    11,517
    14,137
    Tampa, FL
    It will be if he solders well and uses the right cap. IIRC, people are putting in a 220uF 16V cap to replace the undersized one.
    That makes sense. The CM is very expensive and they don't want you keeping it & selling it yourself. If you do that, then they have to buy another one to replenish their stock. I would expect a core fee unless you want to send yours in and wait for return shipment.
    If you're having physical challenges, removing the CM isn't something you'd enjoy. You do have to spend a little time under the dash as well as doing some twisting & turning.
    Hybrid Hobo likes this.
  8. Hybrid Hobo
    Hybrid Hobo Member
    199
    50
    New Jersey
    I'm trying to sleep in the Prius now, before getting all this sorted out tomorrow. Force shut the car off by holding the power button for 3 seconds, and that brought up another issue...
    While the car is off, the power button is glowing green, as is the key fob slot indicator lights. Probably because I'm in the vehicle with the keys/fobs. Will that drain the battery overnight? Better to leave the car on?
    The overhead dome lights wouldn't even dim out like usual, until I manually clicked the switch to the OFF position.
  9. Another
    Another Senior Member
    1,818
    515
    Naples, Florida
    Supposedly these work
  10. prius16
    prius16 Active Member
    462
    243
    New England
    2022 Prius Prime
    A quick simple fix is to wrap aluminum foil around the key fob.
    Also, try putting the key fob inside your center console. That may furthest away from all of the antennas. Plus, the body of the console will attenuate (reduce) the signal strength from the key fob.
    Good Luck!
  11. Hybrid Hobo
    Hybrid Hobo Member
    199
    50
    New Jersey
    UPDATE - After force shutting the car last night, I woke up this morning to the instrument cluster working again!
    This is the second time this has happened in about 2 weeks. First time I simply restarted the car and it came back on, and last night it was out for many hours until I woke up and checked it.
    There's obviously an issue with it and needs repair, but the million dollar question is...
    Do I roll the dice and let it be while I head out on my next multi-week camping adventure, or spend the bucks to get it fixed prior to leaving?
    I found a GREAT guy here in NJ who ONLY fixes clusters, but not sure if I should just live with the problem or spend the $400 or so I'm guesstimating it'll cost to remedy.
    I know that the vents are failure points when taking the dash out and making the repairs. Are these expensive fixes/parts if they should be affected during the procedure?
    Also, can someone explain the importance of the fuel bladder issue. Apparently it also needs to be reset along with the cluster. Or something like that. Thanks
  12. PriusCamper
    12,064
    4,896
    There's actually an antenna mounted underneath the console...
  13. PriusCamper
    12,064
    4,896
    Yep... This problem comes and goes, which is why after near two years of symptoms first arriving it hasn't' gotten bad enough to deal with. Every time it goes out I start making plans to repair it, then it comes back on...
  14. jerrymildred
    11,517
    14,137
    Tampa, FL
    If it was me, I'd prefer the reduced hassle of having it fixed before the trip. But that's just me.
    I wish you lived closer. It's not hard once you've done a few. I know people who can replace it in about 25 minutes. (Takes me a few minutes longer. :D) Of course, the solder repair will add to the time, but not all that much.
    There are 3rd party vents that cost less than the overpriced OEM ones. Here's one I found with a quick Google search. It's the one mist likely to break. Vent cover
    Whether you replace it depends on how badly (if at all) it breaks and how picky you are about little cracks.
    For some reason, if the new CM shows mileage more than a few miles (don't know the exact number) off from the original, you need to recalibrate the fuel gauge. It's in the running for the most non-intuitive chicken dance ever devised.
    Calibrate G2 fuel level gauge after CM replacement
    • Do on level surface
    • If car is on, turn it off
    • Turn it on
    • Put it on trip A
    • Turn it off
    • Keep foot off the brake
    • Press & hold trip button
    • Press power button twice
    • Release & press trip 3 time and hold on the 3rd
    • Wait till odo displays series of six letters & numbers
    • Release trip & press & hold it again
    • ODO will change to 5 letters & numbers
    • 3rd digit quickly change to a 1
    • Release trip button
    Who dreams up this crap??!!
    Another likes this.
  15. PriusCamper
    12,064
    4,896
    Hey Hobo,
    Seems like if you're hitting the road for several weeks you'll be able to drive to someone on PriusChat who can do this for a low price...
    jerrymildred likes this.
