Instrument Panel failed this morning, now works. Replace ASAP?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hearsay, Aug 13, 2015.
  1. hearsay
    hearsay Junior Member
    25
    Silver City, NM
    This morning the instrument panel failed to turn on, and the car was unable to calculate MPG on the MFU, while everything else seemed to work just fine. Is this ever a one-off problem, or a clear sign that the Panel is on it's way out? I have read that Toyota extended a warranty to 9 years for this problem, so I think it should be covered on my 2008 model with 138k. I'd like to nip this in the bud without having it fail on an upcoming road trip, but don't necessarily want to waste my time at a dealer unnecessarily either...
  2. vskid3
    vskid3 Active Member
    773
    228
    It'll likely get worse as time goes on, so you might as well get it done now before it becomes a nuisance.
    49,741
    might as well. from what i've heard, the dealer doesn't have to see that it's not working, they have to take your word for it.
  4. hearsay
    25
    Silver City, NM
    I'll probably take it in tomorrow just to get it over with. It's been fine for the reminder of the day on short trips, but total failure seems to be inevitable. Besides, having our only car in the shop is a good excuse to bike absolutely everywhere..
  5. hearsay
    25
    Silver City, NM
    Well, this is unfortunate: the dealer has stated that they can only perform this service under a warranty claim if you bring the car in to the shop while the instrument cluster is not working. I told him that it was intermittent, and he said if I turn the car on and it is black, then I should drive directly to the dealer without turning the car off so that they can verify. Otherwise, they can't do the work under the warranty enhancement. This is really unfortunate, and I guess I'll just have to wait until the problem gets worse and worse before having it repaired.
  6. bisco
    49,741
    i don't think they are correct. contact toyota customer service for a definitive ruling.
  7. jdenenberg
    jdenenberg EE Professor
    3,860
    1,861
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Print out a copy of the extended warranty TSB and have the dealer read it.
    JeffD
  8. vskid3
    773
    228
    They 110% don't need to see the failure, it says so right in the TSB. If they still won't do it after pointing this out, call Toyota or go to another dealer.
  9. hearsay
    25
    Silver City, NM
    VSkid3, I just got off the phone with Toyota Customer Service. At first the manager on the phone tried to tell me that the dealer had to visibly witness the failed combination meter firsthand. I pointed out the verbage on the document and we read it together. She then agreed that it should be repaired without problem. We live in a fairly remote town, and our local dealer is currently without a certified hybrid tech so they can't handle the warranty claim supposedly. Now I've got to drive 2 hrs to the next closest dealer, and these are the ones that were trying to fight me on it.
    I was advised to drive to the dealer, escalate the situation to the manager there, and if necessary call Toyota Customer Service while on the spot. I'm not willing to drive 5 hrs to the next closest dealer to have this fixed. I'm really hoping that the rental car will be provided to me for free, and not at $35 like the bulletin suggests. I'll post back once I make the trip to the dealer in the next few days.
  10. hearsay
    25
    Silver City, NM
    Just to post an update for anyone who has this problem in the future: Toyota did wind up fixing this free of charge. I was provided a rental vehicle (Camry) free of charge for the 5.5 days it took to receive the new instrument cluster and replace it. In the end I had no problems once they received the car. You definitely have to stick to your guns on this one and quote the Toyota documentation as needed.
    The rep I spoke with at the dealer said they'd seen a handful of these in the past. If that is the case, I don't understand why I had such a hard time initially getting them to admit that it was covered under the warranty extension. My assumption is that they are doing lots of these repairs and actually charging customers for it, especially assuming most customers are unaware of the warranty extension. I'm grateful for this forum and finding that there was an option to have this covered by Toyota.
    wjtracy likes this.
  11. wjtracy
    wjtracy Senior Member
    11,329
    3,593
    Northern VA (NoVA)
    I wish mine would hurry and fail ours is 9 years old in less than 3 weeks.
    Our MFD does seem to be going haywire re: can't keep it calibrated for touch, but I don't think that is same issue.
  12. Freedom
    Freedom Active Member
    535
    69
    Northeastern MA
    Could someone tell me what is the instrument cluster at issue in this thread? Is that the MFD - the touch screen - or not?
  13. jdenenberg
    3,860
    1,861
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It is not the MFD. It is the information that is projected (e,g, speedometer).
    JeffD
    Freedom likes this.
  14. Freedom
    535
    69
    Northeastern MA
    Thanks. Was confused by the comment that it could not calculate MPGs.
