Instrumentation Lighting at Night
Discussion in 'Prius v Main Forum' started by buckaroo, Dec 2, 2011.
  1. buckaroo
    buckaroo Junior Member
    64
    Austin TX
    The night instrument lighting at night is a bit sparse in the Prius v. It is much darker in there than I thought and I may have to supplement it with some other lighting. Not used to that part of it. It is a small concern and I can probably have some mini-LEDs in there but it is a bit disconcerting for me right now.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Have you tried adjusting the instrument panel dimmer wheel to your lower left? You can push it all the way up until it clicks and it will convert back to daytime light levels that is plenty bright at night.
  3. buckaroo
    64
    Austin TX
    Yes. Still not bright enough.
  4. dz302
    dz302 Prius Rookie
    South Carolina
    Amazing, because when mine is all the way up, it's too bright for my personal taste, so I turn it down.
  5. jdcollins5
    5,131
    1,338
    Wilmington, NC
    The only time that I can keep the dimmer all of the way up is right at dusk or dawn. At dusk, I have to cut it back as soon as it is really dark outside as it is way too bright for my taste.
  6. 66Zoomie
    66Zoomie Junior Member
    Apple Valley, CA
    I agree completely. Drove it at night last week and noticed three "areas of deficiency:" a) the shifter is so dark that the pattern can't be seen unless one of the lights above the mirror is turned on [yeah, I know, there are only two choices - R and D - but having owned this Prius v only a couple of weeks, it's still new to me!]; b) the panel light rheostat in front of the left knee isn't lighted at all, and turning on a light above the mirror doesn't help one bit; definite design oversight there; and c) neither the driver or the passenger footwells are illuminated, and they should have at least an led in each side.
    If someone else agrees and comes up with a relatively easy fix with mini-LEDs, please tell us!! 66Zoomie
  7. buckaroo
    64
    Austin TX
    I am going to look for some mini-LEDs to address the lower left side of the drivers' cockpit. I hate that I have to do that. You would think Toyota would have noticed that. Would like to draw the power from the vehicle itself but not going to mess with the vehicle due to warranty concerns. May speak with dealer about a possible fix.
  8. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    That's odd because footwell lights were standard on Ausiie 2010 Gen IIIs
  9. Tideland Prius
    16,125
    Hmm, that's weird. On the regular 3rd Gen Prius, the shifter is illuminated by an overhead LED light, that's why it has no backlighting. There should be one on the v.
    Also, I thought footwell lighting was available on higher trim levels (it is on the 3rd Gen Prius Four and Five models)
  10. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    What about the mirror controlls,are they illuminated ?
  11. BlizzardPearlV
    BlizzardPearlV Junior Member
    35
    My Touring and tech package has footwell lights. They are sort of an amber colour. Also when my shift knob is sitting in its resting position there is back lighting that I believe lights up the shift pattern. You lose the lighting once you move the shifter but you can just reference the shift pattern on the instrument cluster too if you are unsure. Its the exact same pattern.
    If I have a gripe its that the instrument panel is centrally mounted. I would much prefer it if it was mounted infront of the driver.
  12. Tideland Prius
    16,125
    Oh so it is backlit? Right I forgot it's now a horizontal shifter, not a vertical one. oops! So it works the same as the 2nd Gen Prius.
    I don't recall Toyota ever illuminating their mirror controls (except the power folding button)
  13. buckaroo
    64
    Austin TX
    I don't recall that the mirror controls are lit. I spoke with the dealer and he recommended an aftermarket shop that could help me. I am going to get some type of LED lighting installed lower by the floor, kinda like theatre lighting for the front and back areas that has a dimmer control.
  14. civicdriver06
    797
    324
    Germany
  15. Tideland Prius
    16,125
