Insulation on panel over oil pan/oil filter part number.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LiamP, Oct 9, 2022.
  1. LiamP
    LiamP Junior Member
    Got my oil change and the idiots didn't tighten the oil pan plug good enough and it leaked onto the pad that is attached to the splash cover that is over the oil pan/oil filter and soaked it.
    Does anyone know the part number to this?
    I found the whole cover with the insulation pad, but I dont need or want the whole thing.
    Thanks for any information.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    just wipe it down
  3. LiamP
    LiamP Junior Member
    Way too soaked in oil to do that.
  4. tankyuong
    1,555
    662
    Central MO
    tear the insulation off
  5. Mendel Leisk
    42,331
    Oily underpanel aside, hopefully you didn’t run the engine dry.
  6. CR94
    CR94 Senior Member
    2,827
    1,241
    Northwestern S.C.
    Most of the absorbed oil could be removed with detergent or solvent. Or to a lesser degree, tediously wicked out with absorbent material like rags or paper towels.
  7. prius16
    prius16 Active Member
    462
    246
    New England
    2022 Prius Prime
    I'd suggest to use the following:
    Code:
    https://www.amazon.com/Grippy-Absorbent-Mat-New-Pig/dp/B00BUB72UY?th=1
    Grippy Absorbent Mat by New Pig | Adhesive Backing | 40" x 32" | MAT3251, Blue
    $25.99
