Intake cam 13050-0T050
Discussion in 'Prius v Technical Discussion' started by D70, Jul 19, 2020.
  1. D70
    D70 New Member
    Ca
    Has anyone installed the latest intake vvt cam 13050-0T050? Do I need to do anything with this pin in the front?
  2. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    I installed that cam gear when I did my head gasket job.
    If I recall correctly, the cam gear is installed and torqued. The process is pretty self-explanatory once you go to do it. After the bolt is torqued, you will then turn the cam gear to "lock" the gear in place.
    Raytheeagle likes this.
  3. johnnychimpo
    johnnychimpo Active Member
    511
    109
    Monterey
    I changed my head gasket but my cams slipped out of position any Idea on how I can set them up right?
    I know I need the cylinder closest to the chain at TDC and both cams for this cylinder need to point up ish to close the valves for TDC.
    this sound right can you point me in the right direction???
