Intake manifold and EGR circuit preventive mantanance?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NewHybridOwner, Jul 13, 2019.
  1. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    Is there anything (apart from installing an OCC) that can be done to prevent the intake manifold and EGR circuit problems that seem to be rather common on higher-mileage Gen3 (and other?) Prii?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Nope :(.
    Just plan on cleaning the circuit every 50k miles or so after the 100k mileage mark;).
    If you have a pressure washer, it makes the cooler cleaning super easy(y).
    spiralhelix likes this.
  3. spiralhelix
    spiralhelix Active Member
    255
    220
    Illinois
    Regular cleaning
    If your really adventurous, rebuild the engine with the updated pistons and rings.
    -Spiral
    Raytheeagle likes this.
  4. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Just be thankful you don’t have a Gen4 or Prime and need to do this task;).
    It may require moving the inverter to get at the nuts on the studs:
    4C75F5B4-2136-4B5B-A157-1D37F90A6C22.jpeg 38C63299-7F89-42AA-9C0F-4A81C7C7F528.jpeg
    So it could be worse (y).
    mikey_t likes this.
  5. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    EGR: Exhaust Gas Recirculation. The harder you drive, the more concentrated your exhaust gas is when it recirculates, the more deposits are left behind. For my money, I would bet that driving habits can, indeed, affect the rate that EGR deposits build up. Begin by using a fuel that minimizes the amount of crud left behind during combustion. That would mean using a high-detergent Top Tier certified gasoline as found at Homepage . Most of the major brands are already there. Then, make a habit of driving as though your low fuel warning light is on. As you burn less gas, the exhaust will be cleaner to begin with. No jack-rabbit starts. No stomping on the pedal. Minimal high-speed driving or trailer-pulling, excess weight- anything you know that will affect fuel economy. All of that would be doubly true on a cold engine, as any combustion engine is inherently less efficient until it reaches normal operating temperature. In short, drive like you want to save fuel, and the EGR maintenance should not be required nearly so soon.
    StarCaller and Raytheeagle like this.
  6. CR94
    CR94 Senior Member
    2,827
    1,241
    Northwestern S.C.
    That's what I've been assuming. No symptoms, so far.
    It would be interesting to know how closely EGR clogging rate correlates with rate of oil consumption, and with mpg, among other variables.
    Pluggo likes this.
