Intelligent Parking Assist to the Left Side?
Discussion in 'Gen 3 Prius Main Forum' started by gjkubel, May 8, 2009.
  1. gjkubel
    gjkubel Junior Member
    Does anyone know if the IPA can parallel park the car to the left side (such as on a one way street)? I'm great at parallel parking normally (i.e., to the right side), but am lousy at parallel parking to the left side on a one way street for some reason. If it could park to the left, then that is a feature I would find very valuable.
  2. sluday
    sluday New Member
    251
    16
    Jersey Shore
    Great question. If the sensors are on the left side of the car as well then it should work. Has anyone seen if the sensors are on both sides of the car ?
  3. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    I'm thinking since there are sensors on both sides of the car it works either side. Same thing for back in parking, the spot can be on the left or right...
  4. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    The big question I've had regarding the Intelligent Parking is "How small a space can it park the Prius into?" or "How many feet above the length of the Prius does it need?"
    In the videos I've seen they're always parking the car into a space that looks to be 6 - 8 feet longer than the Prius.
    For me, if it can't park the Prius into a space that's only 2 feet longer than the car, then I have no use for it.
  5. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    I'll let ya' know by hopefully June 15th! lol
    I work in Brooklyn so I am sure I can find several small test spots to try
  6. Tideland Prius
    16,066
    Yep you can park on both sides. Just press the soft button to switch sides.
