Interchangeable parts
Discussion in 'Gen 3 Prius Main Forum' started by MBoyd, Nov 20, 2024.
  1. MBoyd
    MBoyd New Member
    Texarkana Texas
    Hello,
    I have a 2013 Prius 3 I believe. Would it have many (engine) parts that would be interchangeable with a 2013 Prius C?
  2. Tideland Prius
    16,429
    No because they're using two different engines. The Gen 3 uses the 2ZR-FXE engine whilst the Prius c uses the 1NZ-FXE. The Prius c is more similar to the Gen 2 Prius.
  3. MBoyd
    MBoyd New Member
    Texarkana Texas
    Thank you for this. Good info. So would only the 2013 gen 3 parts be interchangeable? Mine has thrown a rod and I want to get something compatible so I can use it for spare parts.
  4. Tideland Prius
    16,429
    In theory, the Gen 3 and 4 as well as the Prius v have the same 2ZR-FXE 1.8 litre engine. (As well as the Corolla Hybrid). I say "in theory" because I don't actually know if there are minute differences as I have not studied the repair manuals. But on the surface, those 4 vehicles use the same engine so there's your starting point.
  5. Brian1954
    Brian1954 Senior Member
    1,705
    665
    South Central PA, USA
    The engine for the Gen 4 was redesigned and is different from the Gen 3.
  6. ChapmanF
    17,186
    It's still a 2ZR-FXE so no really radical differences, but a bunch of small amendments add up.
