Interesting talk on automotive electrochemical storage
Discussion in 'EV (Electric Vehicle) Discussion' started by cycledrum, Apr 8, 2011.
  1. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Make that electrochemical energy storage - batteries. Nov. 2009 Talk at UC Berkeley from the Chemical Sciences and Materials Lab Director at GM. Very knowledgable and speaks well.
    bits from 1st half -
    * Li Ion are the major traction batteries currently
    * Increasing world population major driver to vehicle electrification
    * Electrified vehicles can use diverse sources of energy
    * 80% traction efficiency from battery to wheels in EV
    * note - GM build bus hybrid drive systems (utilized by Gillig in Hayward,Ca)
    * Cost a challenge in EV's - batteries & electronics are expensive
    * GM calls Volt and EREV because w/ range, ICE will not come on with flooring pedal
    * 10 million EREV's (Volts) would only impact grid by 0.9%
    * EREV40 requires 2.5x power over PHEV40
    2nd half more technical with battery electrochemistry -
    * challenging to estimate battery SOC
    * using dual negative electrode materials to estimate system state
    * promising future using higher capacity electrode materials
    * currently using about 300 mAh/g electrode materials.
    * Silicon based materials could provide 1500 mAh/g, but challenges to overcome
    * chemical and mechanical degradation in Li Ion batteries due to solvent reduction and material surface cracking from expansion / contraction (charging/discharging)
    and a lot more.
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    wow 54 mins?? can u summarize?
  3. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    filled in above.
