Interesting things you learned about the Prius long after buying it
Discussion in 'Gen 3 Prius Main Forum' started by Johnny Cakes, Dec 5, 2019.
  1. Johnny Cakes
    Johnny Cakes Senior Member
    1,044
    780
    Virginia, USA
    This was an interesting thread in another car forum I used to participate in (before buying the Prius), so I port it over here. I learned a bunch of offbeat things about my last car that people had discovered, and maybe this will be the same.
    I'll start off.....
    On the steering wheel control for the radio, if you "double click" when you are at the bottom (or top) of a bank of channels, you will stay in that bank and go to the top (or bottom) of that same bank. A single click takes you to the next bank of channels.
  2. Mendel Leisk
    41,108
    We had ours for maybe 3 years before I noticed the upper glove box...
    Wonder, partiks, m.wynn and 10 others like this.
  3. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    Trip A & B will not go pass 9,999.9 miles :mad: Kept thinking no one else drives this car, so who keeps resetting my trip B miles driven?
    dig4dirt, vlxerdon and Johnny Cakes like this.
  4. elementnomore
    elementnomore Member
    136
    44
    Los Angeles
    AND the top glove box perfectly fits a bottle of champagne
    AdrianAsu, CindyLouWho and dig4dirt like this.
  5. Rebound
    Rebound Senior Member
    3,995
    2,643
    Portland, OR
    Maintenance is very easy, and the brake pads last FOREVER. It’s a great car for teaching driving to teens.
    It holds a LOT. I brought a boxed water heater home in it. I’ve camped in it... in 100 degree heat, you can run the AC all night and barely use any gas.
    Wonder, toddrav and kc5dlo like this.
  6. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    After trip to Alaska and tire blow-out in Yukon, I bought a full-sized rim and spare tire. I was surprised to find that it would fit in the place for the donut spare if I removed all the foam pieces and moved the jack into the compartment with the black plastic bin (just above the tire and below the floor sections).
  7. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    Before taking your car in for any work at stealership or mechanic, press the ‘trip’ button to display lifetime miles driven. They will eventually erase trip A or B and both when they fumble through to write down lifetime miles.
    toddrav and Johnny Cakes like this.
  8. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    The top glove box doesn’t hold enough alcohol, speaking from experience.
    Tim Jones and dig4dirt like this.
  9. Rebound
    3,995
    2,643
    Portland, OR
    Nor should it!
    partiks likes this.
  10. bettergolf
    bettergolf Active Member
    487
    366
    Sanford NC
    That's why it has 2?
    toddrav likes this.
  11. Mendel Leisk
    41,108
    I don't know: every time the car is turned off, regardless of what displays were active, it shows the odo reading, for about 30 seconds. That's my "go to" when gassing up and recording the odo.
    AcidSun and Merkey like this.
  12. RRxing
    RRxing Senior Member
    2,540
    1,816
    NEPA
    I was surprised how many people didn't know there were two recesses in the hatch to pull it down to close it.
  13. RRxing
    2,540
    1,816
    NEPA
    Edit - This is on the Gen III
    Wonder likes this.
  14. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    Here's a weird one I confirmed after a week long; If your keyfob is low on battery and get the warning screen after powering car off, the low key fob battery screen goes away if your maintenance is due warning screen comes on when car is powered up. Been seeing the key fob low battery warning screen for 4 months, suddenly low bat screen dissapared after maintenance was due
    #14 Grit, Dec 9, 2019
    Johnny Cakes likes this.
  15. Johnny Cakes
    1,044
    780
    Virginia, USA
    Wait, what?? Or more importantly, where?
    fuzzy1 and Mendel Leisk like this.
  16. Tideland Prius
    16,530
    One on each side of the inner plastic cover of the hatch.
    They’re recessed so you reach around with your palms facing you.
    Merkey likes this.
  17. AzWxGuy
    AzWxGuy Weather Guy
    1,048
    532
    Tucson, AZ
    2021 Prius
    Isn't there also a little air venting from the HVAC through the top glove box, to perhaps keep cool said bottle of champagne? Or is that in the VW Jetta, can't remember.
  18. RRxing
    2,540
    1,816
    NEPA
    On the underside of the hatch when open...
  19. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    That I do know. Now if the person wanting to get the mileage driven would know.
  20. Tande
    Tande Active Member
    536
    319
    Mich.
    Yup.......and only one on the gen.4......& it's in a ridiculous location (IMHO)......gen.3 had it all figured out.......:mad:
