Interior Bulb. How hard is it supposed to be to get out?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Jeffersonalan, Oct 24, 2016.
  1. Jeffersonalan
    Jeffersonalan New Member
    Hamilton, Ontario, Canada
    So got myself a set of led bulbs to replace my interior lighting on my 2014 Prius IV. Yaa me!
    Thought it would take 10 miutes maybe 20 tops to switch out the bulbs but after I couldnt get the bulb out of the map light or the vanity light I stopped. I was worried I was gonna crush the bulb in my fingers or tear it from the socket.
    Is it supposed to be that difficult to get those bulbs out? Or am I missing something?
    glutaman likes this.
  2. Dshin525
    Dshin525 New Member
    Ann Arbor
    I had some trouble with some of the bulbs. I had to use a plier (with paper towels wrapped at the tips of the plier) to get them out.
  3. Jeffersonalan
    used pliers, conversion done, looks great!
  4. joereres
    joereres Junior Member
    New York
    I changed every bulb on my 14’
    Gen IV . I loved it , the interior seemed too bright and I changed the interior lights to red . It looked great , and when I approached the car , the red grew brighter before unlocking . I was thrilled !
    The interior lights stopped working . T can turn the lights on with the switch , but opening the door the cabin stays dark . Any thoughts ?
    Has the resistance of the led confused the computer ?
    iPhone ?
  5. Grit
    Grit Senior Member
    6,139
    4,053
    Wilkes Land
    How did your high beams and side markers in the headlight go?
    joereres likes this.
  6. Mendel Leisk
    38,644
    There's pliers for gripping hoses, have concave curve to their "grippers". Not sure if they'd clamp down tight enough, but if they did, and you dipped them in plasti-dip for a few coats, maybe that'd be the bee's knees?
    Or these. I'll just do a screen grab, since Amazon Links don't display with a lot of ad-blockers, at least not here:
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,148
    2,202
    Taylors, SC
    A cheap rubber jar opener or a grippy pair of rubber gloves will do the same thing.
  8. Mendel Leisk
    38,644
    I use an oil filter pair-of-pliers for opening spaghetti sauce jars and the like; without that we'd likely starve to death. :ROFLMAO:
  9. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    There is a thread in the "What have you done to your Gen III" section or the section that covers modifications that has this. It is not as easy as it looks. Some people took their cars to people who have done it (can't really do that now).
  10. joereres
    New York
    It went fine once I was able to jam my Hand in there .
    The lower bulbs were done by loosing the lower cover
    iPhone ?
    Montgomery likes this.
  11. joereres
    New York
    No real problems on any bulb , I did consult u tube to see how to open the interior bulbs
    iPhone ?
  12. joereres
    New York
    I received a suggestion on what to check . It was a switch issue . I did not remember touching it but when I checked it was rolled down which lowered the lights to off . Now the interior glows red as I approach ( the white interior bulbs were way too bright ) Sorry for the delay on the update . But ,
    Thank you for the help
    iPhone ?
