Interior lights do not go on
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by csk47, Nov 20, 2020.
  1. csk47
    csk47 Junior Member
    Port St. Lucie, FL
    I have a 2016 Prius and for the last several months my interior lights do not go on where the doors are opened. The only light that does go on is at the bottom of the front doors. Perhaps I inadvertently flipped off a switch, I don't know. I appreciate any and all help.
  2. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    Check the switch on the middle front of the ceiling. It needs to be in the middle position. One side is On, the other is Off, the middle position is on with doors open.
    Failing that, it could be the fuse, but I think that feeds the lights under the doors too and maybe the switch illumination.
    SM-T813 ?
    jerrymildred and krmcg like this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    There's a similar switch on the light over the back seat.
  4. csk47
    csk47 Junior Member
    Port St. Lucie, FL
    I went outside to check if I had a switch in the wrong place. I saw that the switch was set to doors but the interior lights did not come on. When I pushed the door part of the switch the lights did come on. It appears I have a short in the switch because it works if I hold my hand on it and put does not work if I don't put pressure on the switch. I shudder to think what Toyota will charge to replace the switch.
  5. ChapmanF
    18,536
    You mean the door button that pokes out from the door jamb in its little rubber boot, right?
    Those things are often dead simple. Your problem certainly isn't a short (that would make the lights be on most of the time, or would blow a fuse or make bad smells). It is probably just poor electrical contact in the switch.
    That could just be oxidation, on a ten year old car in a humid state.
    Usually with that kind of switch if you take it out you can see right away what to clean so it works right.
    jerrymildred likes this.
  6. alanclarkeau
    7,045
    7,593
    He said it's a Gen4 - 2016. I've had them go bad in that time before. As ChapmanF says, they're often an easy clean - in older cars it was just an earth return - which only connected with the door open. Used to be like this - run some wet/dry through the contacts and it works again. One screw to undo, hidden behind the rubber cover. Pull the fuse first is probably a good idea - at least I should suggest it, even if I may not do it myself.
  7. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Or you could swap it out with the passenger side one.
    alanclarkeau likes this.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    You said the lights don't come on when the "doors are" (plural) open. It seems unlikely that all five door switches have corroded, assuming as you said that the switch is in the right position. And as @ChapmanF very accurately pointed out, there's no way it could be a short and the fuse doesn't seem right either. That leaves the switch on the front dome light. If the regular Prius is like my Prime, the switch on the back seat light does not have an "off" position; just "on" and "door."
    Those switches always look to me like something someone cobbled up out of scrap. Most likely, you can take it apart and clean it up. It might take a little fine sand paper and some slight bending to get a solid contact again.
  9. alanclarkeau
    7,045
    7,593
    I just went out and checked - only 2 positions on mine too. But then - I only ever go in the back seat ... with a vacuum cleaner occasionally.
  10. jerrymildred
    11,517
    14,157
    Tampa, FL
    Same here. I had to go look for that same reason.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    FWIW The rear interior light, when switched to the "door" position goes off when you switch the front one to the "off" position.
  12. alanclarkeau
    7,045
    7,593
    Ahh - I'll keep that in mind next time a Grandchild dabbles with it. Though - I told him off when he did it - last thing I want was to discover it had flattened the battery.
    Odd chain of events. I was driving 4 of them home from school and saw "A" reach up to the light while stopped at the traffic light. I said to turn it back to door. He didn't understand - but fiddled with it again. I opened my door to check it was on door - yep, OK. Waited for the traffic light to turn GREEN - then hit on accelerator. NOTHING. Quick think. Stupid thing had taken it out of "D" when I opened the door. GRRRR.
    jerrymildred and kithmo like this.
  13. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    If they switch the rear one to "ON" it will stay on even if you switch the front one to "OFF"
  14. alanclarkeau
    7,045
    7,593
    Ahhh!! I think they're supposed to turn off after 19 minutes anyway - or at least my KIA used to.
    But when I had the KIA - which turned lights off after a reasonable period, we had a TARAGO/ESTIMA/PREVIA at work - with at least 5 interior lights - and children on board EVERY day. Which DIDN'T turn them off ever.
    And so it had flat batteries quite often - at least monthly or more often. The car was parked every afternoon in a very bright location - so it wasn't obvious to the drivers - who had a lot more on their minds than "are the interior lights off". Was quite annoying. I suggested we should take all the bulbs out - but they pointed out that the vehicle was used for after-hours call-outs. Oh, well.
    kithmo likes this.
  15. The Professor
    598
    809
    UK
    Excel
    Curious... Mine doesn't do that. It just makes a continuous beep and displays "Shift to P before exiting vehicle".
    SM-T813 ?
    krmcg likes this.
  16. krmcg
    2,592
    2,392
    Whittier, CA
    same.
  17. alanclarkeau
    7,045
    7,593
    OK - I'll go do a "grand-children-less" test when I'm out next.
    The Professor and krmcg like this.
  18. Khristina
    Khristina Junior Member
    Barksdale AFB
    I tried looking to see if this resolved the problem with the interior light but I’m not seeing it. I push up on the switch and the light comes on but I let off the switch it goes off again. Any help would be appreciated.
  19. Doug McC
    Doug McC Senior Member
    1,081
    420
    Midwest
    2022 Prius
    Which switch are you referring to, the the one in the center front?
  20. Khristina
    Barksdale AFB
    The light switch on the ceiling between the driver & passenger seats.
