Interior lights when opening doors
Discussion in 'Gen 4 Prius Audio and Electronics' started by Ampletum, Jun 23, 2018.
  1. Ampletum
    Ampletum Junior Member
    Greater Manchester UK
    Excel
    I have a Prius excel (uk version) and the interior lights do not come on when I open the door. The lights function ok when I switch them on manually but do not come on automatically when I open (any) door. Does anyone have any ideas?
  2. Tande
    Tande Active Member
    502
    302
    Mich.
    You DO have the "Selector Switch" set to "Door"?? .....
    Harters and krmcg like this.
    49,488
    is the door switch stuck closed?
  4. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
  5. Ampletum
    Excel
    Thanks for the replies, I have the switches set as per the diagram but where us the door switch mentioned by bisco?
  6. krmcg
    2,592
    2,390
    Whittier, CA
    on the door jamb
  7. alanclarkeau
    7,044
    7,584
    Sounds odd - so neither front nor back light comes on with any doors? But both work with the on/off switch. So the fuse must be fine.
    If it's the switch - it would be extremely unusual for both switches to go bad at the same time in such a new car.
    My recollection of older cars when I had to repair a door-switch not working - the switch simply completes the circuit to earth. Again - it would be extremely unusual for all 4 switches to go bad at the same time. Though - PRIUS might have some new artificial intelligence method of detecting that the door is opened - but I doubt it.
    I assume the car is in good condition - ie no body rust?
  8. Harters
    Harters Active Member
    335
    424
    UK
    Excel
    You overhead button needs to be flat like this.
    Door switches are in the door jams and are like little rubber mushrooms. Give them a little wiggle just in case they are stuck, unlikely, but just in case.
    Hope this helps :)
  9. Ampletum
    Excel
    Hi Guys,
    Thanks for all your input. The answer was embarrassingly simple - switch the interior lights on in vehicle settings and choose your time. Easy when you know how
  10. alanclarkeau
    7,044
    7,584
    That's odd - they should have just worked. I've read every Gen 4 PRIUS post since the model came out - and this hasn't ever been an issue mentioned.
    Or did you buy the car 2nd hand - maybe the previous owner had disabled it?
    Starship16 likes this.
  11. Ampletum
    Excel
    The car was an ex demonstrator so perhaps the setting had been changed by the . dealer though I can't think why
  12. alanclarkeau
    7,044
    7,584
    That makes sense. I remember a long time ago they'd take the bulb out of the interior light at car shows so the batteries didn't go flat with the doors open all day. If they can program it to not turn on - that's probably what they did, and forgot to fix it when they sold it to you.
    kithmo and Starship16 like this.
  13. Starship16
    Starship16 Senior Member
    1,348
    1,453
    Beach Christmas
    My vehicle settings allow me to set a time for when they go off... after you exit the car and close the door. They fade out after about 15 seconds.
    But there's nothing about turning them off permanently.
  14. alanclarkeau
    7,044
    7,584
    It looks like a dealer adjustment (or Carista?).
  15. Starship16
    1,348
    1,453
    Beach Christmas
    Thanks Alan. I've never seen that before. Maybe the U.S. cars don't have it? I wil look again.
  16. alanclarkeau
    7,044
    7,584
    That was Australian Manual (I got online - didn't check mine).
    Here is USA Manual - seems much the same:
  17. Starship16
    1,348
    1,453
    Beach Christmas
    Nope. I don't have that. My settings only show the "'time elapsed before the interior lights turn off."
    I wish I could disable the two lights in the front doors. (in the lower door panel.) They are always on when the door is open. No way to turn them off... Can I just take the bulb out? Will that cut the power?
    #17 Starship16, Jun 28, 2018
  18. alanclarkeau
    7,044
    7,584
    You could try - but some modern cars are so "clever", you could find that it triggers a bulb failure warning. Which you could ignore - but then it wouldn't tell you if another more important bulb/s burn out.
    Worst case the flux capacitor might be activated?
    Starship16 and krmcg like this.
  19. Starship16
    1,348
    1,453
    Beach Christmas
    Ok sir, I will leave well enough alone. Thanks.
    #19 Starship16, Jun 28, 2018
  20. alanclarkeau
    7,044
    7,584
    Oh, no - I was waiting with bated breath to hear about the Flux Capacitor ...:cry::cry::cry:
    Tande and Starship16 like this.
