interior plastic scratches- disappointed!
Discussion in 'Gen 3 Prius Main Forum' started by springfield, Sep 20, 2009.
  1. springfield
    springfield New Member
    30
    Springfield, VA
    I've had my new genIII for three months and have light scratches on the door panels and console. They don't "rub" out like all other cars I've owned. I think it's because they are made of recycled plastic. Don't want to think about how my car will look in one years time.
    Anyone know how to minimize them? I saw a post about using vaseline and it didn't work.
    Also have rattles in passenger air vent and console. I'm not impressed with this car's interior integrity at all.
  2. DMHAK
    DMHAK New Member
    Oregon
    We too have the scratch problem in the plastics, it's not too bad (we've had the car since end of May), but it is noticeable. Would love to see if others experience this as well. We don't have any rattling and I'm generally extremely happy with the vehicle.
  3. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    Unless you have kids, how the heck do you get scratches on the plastics? When I'm in the car, the only places my body touches are the leather/pleather/vinyl.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I have them too. Where my feet scrape the threshold, where my keys hit the center console a couple of times, etc. The thing is, I had all the same kind of scratches in my 97 Camry. I don't think there is any difference with the Prius. Its tough to see in a new car but you will get over it.
  5. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    The plastics that Toyota is using in its new cars do seem to be more prone to scratching than the older plastics they used previously. Not a whole lot you can do but be careful...
    Lighter colors show scratches less...
  6. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    you might try a heat gun to "heal" the scratches. I've done this using my wife's small crafting heat gun. The idea is to gently heat the plastic until it almost melts, at which point the scratches get filled in. You should see the plastic start to glisten when it's about hot enough. It can be very easy to go too far & do more damage than repair.
    The drawback I discovered is that the area treated looks different from the surrounding area. If you try this, try one scratch in a relatively inconspicuous place. Good luck!
  7. SW03ES
    2,480
    176
    Gaithersburg, MD
    Yeah I think in general thats a bad idea. You can very easily make the situation look worse...
  8. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    don't do it.
    i tried it once with a vinyl door panel with a small hole. vinyl turns too quickly and it shrinks when it gets close to it melting point.
    and i was using a hairdryer very carefully
  9. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    I feel the same - the plastics seem to be subject to easy scratching. The interior around the dash and console, although attractive IMO, do not have a nice feel to the touch and may have poor durablity. I have a few light scratches - the big ones where the tonneau cover latches in the back. I feel sorry for the folks that have kids or use the car for hauling and/or moving things around the interior. Afraid it will age quickly.
    Although I love the car, overall the interior material quality is not quite where it should be. Inexpensive Hondas, Kias, Hyundais, seem to have better material quality.
  10. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Scuffs on interior plastic are easily cleaned with the "Mr Clean Magic Eraser". Use it with a little water. Note that there is now a cheaper alternative to the Mr Clean product, and it works just as well. If the plastic is actually scratched (grove in the material) then it will only remove any dirt/residue from the scratch. It will be less visible but will still be there.
  11. mattjw83
    mattjw83 New Member
    Illinois
    I too have a few scratches on my glove box. I think the weird texture of the plastic makes it susceptible to scratching easily. I also put a light scratch on the plastic behind the center arm console with a washcloth! That was the 1st scratch and the most annoying since it was a soft cloth! The tag rubbed against the plastic... :p
    Oh well, it is only a car afterall. No complaints about anything else. Runs great and gets AWESOME MPGS!
  12. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I wouldn't say that... our Kia Sedona has all the same scratches in the dash, etc. However with the lighter color in the Kia they blend in a bit more.
  13. MaggieMay
    MaggieMay Active Member
    534
    68
    Gloucester, MA
    Oh gosh - the first week I had my car I sat in the driver's seat with glasses in my pocket and scratched the side of the center console. I shed a tear, learned a lesson and figured it was a christening of sorts. Now I'm very gentle with any sharp objects.
  14. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    Come on, fess up. We all know it was the ruby you wear in your belly button that caused the scratch. :photo:
  15. Mark57
    2,945
    2,735
    OK
    Remember, don't run with scissors, or in this case, drive with them.:D
    In a previous vehicle, I was working in the garage and put a pair of needle nose pliers in my back pocket for just a moment. My wife came out and wanted to do a quick errand so we hopped in the vehicle to go and just as I sat down, I remembered the pliers (sharp end up) but too late before they poked a small hole in the seat fabric. I was not pleased with myself at all.
  16. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    It's those "quick" moves that will get you every time. Like hurrying someplace and forget to take your keys...Thank God if you do that in the Prius with SKS, You can open a door! :)
  17. SW03ES
    2,480
    176
    Gaithersburg, MD
    I would be VERY careful using a Mr.Clean Magic Eraser on interior plastics. They are VERY abrasive and have a very harsh bleachlike cleaner imbedded in them. I have seen people ruin dashpads with Mr.Clean Magic erasers...
    Not a car care product IMHO...
  18. bluemonday
    bluemonday New Member
    151
    26
    St. Louis
    I have seen a couple references to the "recycled plastics" being at fault. I am not aware that these are made from recycled plastic, but would be happy to learn I'm wrong.
    Maybe people are confusing it with the plant-based plastic used in the vehicle? But the dash is also not made of this.
  19. azgringo
    azgringo New Member
    109
    24
    Phoenix, AZ
    It seems that the plastics used in the Prius are a bit "waxy" to the touch. I, too, have easily scratched the center console. If fact, you can scratch it with your fingernail! I love this car...BUT wish Toyota wouldn't have skimped on the interior quality. Once the scratches are there, they're there. I don't know of anything that would get rid of them. Someone mentioned Magic Eraser, but I would advise against that. I've used this item before and based on my experiences I think it would be too harsh on the delicate Toyota plastics.
  20. jim256
    jim256 Member
    317
    69
    Eastern NC
    I think the goal is to produce "soft touch plastics" which almost feel like they have a thin spray of vinyl on the surface. When car mags review new cars they universally condemn hard plastics now and praise the soft touch kind. It may be they are slightly more vulnerable just because of this softer surface layer to enhance esthetics.
