Interior wear and tear
Discussion in 'Prius c Main Forum' started by Snowball, Oct 28, 2013.
  1. Snowball
    Snowball Junior Member
    48
    Southern CA
    Last week I was backing up the C and I placed my hand on the back of the front passenger side headrest. I placed some slight pressure with my fingers and I felt the foam crush under my fingertips. I was very alarmed that the foam gave way so easily and I'm afraid I've damaged it. I can only describe it as small open cell styrofoam that crushes with light pressure (3-5lbs pressure?) and doesn't rebound. If I feel around, I can find the light depressions left in the foam. It makes me think if I had whiplash in an accident the headrest would need to be replaced from my head striking it.
    My 1998 Honda Civic was in excellent shape, but I only had 160,000 miles over 15.5 years. In the last 5 years, I drive round 5000-6000 miles a year.
    For those of you that have had your Prius C for a year or so, have you noticed much wear and tear? The interior isn't the most luxurious and I'm a little concerned how it will hold up long term.
  2. CraigB
    CraigB Member
    205
    96
    SF Bay Area, CA
    Haven't noticed anything like you've described after 1.5 years, but I can say my wallet has left a nice crease in the driver seat....and it's definately not from being loaded with money.
    B2FiNiTY likes this.
  3. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    in my c1 the headrests are strong. have any pics of what exactly happened? toyotas have been pretty strong for me.
    the only nasty part i hate about the interior is the little cloth armrest on the front doors. i hope its easy to re-upholster it.
    CraigB likes this.
  4. Daniel Moore
    Daniel Moore Junior Member
    29
    Cramerton NC
    On the armrests do you think that could be a diy sort of thing, surely any auto upholster shop definitely could.
  5. Fauxknight
    Fauxknight Active Member
    210
    116
    My carpet floor mats are getting chewed up from me constantly getting in and out for deliveries, tearing at the attachment point. Aside from that everything seems to be holding up fine. Gonna replace the mats with Weathertech or similar, which should hold up a bit better.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    You might indeed need to replace the headrest if you were in an accident that resulted in a significant impact to the headrest. My speculative guess is that it is designed to absorb X amount of energy and impact, which like a motorcycle of bicycle helmet might include using a filler that "crushes" or absorbs impact but isn't designed to rebound.
    This is too bad if the headrest is crushing with just simple day to day handling. I've never had a vehicle in which I couldn't at least grab the headrest with "normal" grip without damage. If this is common it may be something Toyota should look at improving.
  7. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    In my c2, the headrest provides a good cushion. When pressed, slowly returns to the original shape. Kinda like a slow moving memory foam.
    carolD likes this.
  8. Snowball
    48
    Southern CA
    Ok, so I take back what I originally said. I guess I wasn't pushing hard enough because the first 1/8-1/4 inch is a crushing sensation. I didn't want to push further that first time I discovered it because I was afraid of leaving a large permanent dent.
    I pressed much harder this morning on the underside of the headrest (so I didn't leave any visible damage) and after the first 1/8-1/4 inch, it will smush like soft foam and rebound after letting go. Though I'm not quite sure if the first 1/8-1/4 inch complete rebounds.
    I want to scotchgard this spot since I think it will get dirty. I wonder if someone will come out with a carbon fiber kit where the upholstery here can be removed and be replaced with a carbon fiber piece.
  9. B2FiNiTY
    979
    226
    Yeah, that portion is easily dirtied. Best to watch out for it.
  10. Larry Greenwald
    Larry Greenwald Junior Member
    67
    16
    2018 Prius
    First thing I got was those clear plastic floor mats. Forgot the vendor name, but they have a full set that matches the C interior. Since my shoes get dirty, I'd rather let the plastic take the beating than the carpet.
