Intermittent A/C Blower Failure - 2005 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Devil's Advocate, Aug 8, 2013.
  1. Devil's Advocate
    922
    Las Vegas, Nevada
    I've got a 2005 with almost 300,000 miles
    and just recently the A/C blower has intermittently
    failed to start up. However, if I give the console
    a smack on the driver's side of the nav screen the unit
    usually starts up.
    Now, I am assuming it is the start of an electric motor failure
    in the A/C Blower unit, however, the blower is apparently
    located under the passenger side glove box. So I am
    wondering if that is whee the blower is why does smaking the driver
    side of the nav screen start up the motor?
    Just wondering if anyone has had a similar experience. Its apparently
    a pretty easy fix to replace the blower motor, and only about a $50 part,
    but when the motor doesn't turn on, the Prius shuts down the a/c altogether
    so you definitely need the motor! lol
  2. Patrick Wong
    18,200
    6,474
    Your assumption is right regarding the location of the cabin blower.
    What happens if you hit the passenger side of the nav screen?
  3. Devil's Advocate
    922
    Las Vegas, Nevada
    Not sure. It hasn't stopped working since I wrote the post, but the next it stops I'm going to try slapping the inderside of the glovebox!
