Intermittent drive-train/transmission vibration
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by John Dostal, Nov 21, 2016.
  1. John Dostal
    John Dostal Junior Member
    2008 Prius Base, 200,000 Miles
    My Prius is demonstrating a vibration in the CVT Drive-Train when accelerating at moderate speed.
    Initial acceleration is smooth, 25-40 MPH there is a steady vibration, then at highway speeds it goes away.
    I had a CV axle go dry and replaced it. I also replaced both Control arms. and the other CV axle. After I replace the Struts and inner and outer tie-rods I will have a new front end.
    I am wondering if anyone has had any issues with the CVT mounts or the lower engine torque strut that I would assume could cause vibration if failing.
    I hope that it is not a CVT problem.
    Thanks, John.
    #1 John Dostal, Nov 21, 2016
  2. Mendel Leisk
    38,893
  3. John Dostal
  4. CooCooCaChoo
    CooCooCaChoo Senior Member
    905
    506
    Cow-lee-fornia
    2023 Prius
    Motor mounts maybe?
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,810
    Clearwater, Florida
    Were seals where axles enter trans replaced when CV joints
    Replaced?
    If not u may be leaking trans fluid.check trans fluid.
    Sometimes trans fails and u will hear and feel vibration
    Front passenger side but in that scenario it will soon
    Throw check engine light for hi volt fault.
    Other way the trans fails is gear wear in diff area of trans
    From lack of fluid maintenance. That will not throw a code
    As strictly mechanical.
    Were u replacing these parts chasing this issue or it happened
    After parts were replaced?
