Intermittent heat
Discussion in 'Gen 3 Prius Main Forum' started by Hisparadox, Oct 3, 2019.
  1. Hisparadox
    Hisparadox New Member
    New York
    so I have a 2012 Prius model 2 Some days the heat does not come up and it just blows cold and then while driving it will kick in with hot air. But when sitting still it will blow how for a while. Like 30 minutes. But then go cold again Any ideas?
  2. BZzap!
    BZzap! Senior Member
    1,607
    877
    Sound like a bad blend door actuator or control.
    Raytheeagle likes this.
    49,430
    air in the coolant? sticky thermostat?
    how many miles on her?
  4. Hisparadox
    New York
    There’s 240,000 on the car. It had an overhead light come on and the reservoir was very low which I refilled
  5. BZzap!
    1,607
    877
    Lots of miles. The coolant being low is a clue that there is an underlying problem that’s baring it’s fangs. Do a thourgh inspection of all the hoses and other areas where you might see traces of coolant leaks. If the engine has any suspicious behavior, I would do a block and pressure check to see if you have any signs of a head gasket failure. With these kinds of miles, it’s highly probable.
    Robert Holt likes this.
