Intermittent misfire low RPM
Discussion in 'Gen 3 Prius Technical Discussion' started by Norm K, Jun 15, 2021.
  1. Norm K
    Norm K Junior Member
    Buffalo
    I get intermittent violent shaking on a light acceleration around 15-20 mph.
    Mostly on a hot engine. If I accelerate moderate to hard the shaking instantly stops.
    Random misfire codes get set but it is usually 1 or 2. No other codes.
    It happens more the hotter it is out. At 85 deg it happens a lot. I drove it 15 miles today at 64 degrees out with about 30 stops and starts and it only happened once for what felt like 3 misfires.
    Gen 3 2010 car has 220,000 miles 5k miles per qt of oil, runs quiet.
    Here is what has been done
    The spark plugs and coil packs have only around 30K
    I changed all injectors
    no difference
    Then the real fun started
    I removed the EGR cooler (was plugged solid), valve and pipe and cleaned them all.
    same problem.
    I replaced the EGR valve and removed the intake manifold and cleaned it (no passages were blocked).
    Replaced the PCV valve.
    Same problem
    Just because it was cheap and easy, I replaced the cam advance solenoid thinking it might have an intermittent coil. no difference
    Since all the engine parts should be the same temperature when the engine is hot regardless of the ambient temperature. I am starting to suspect the ECU computer. No 85 deg days currently in the forecast when I get one I'll pack the ECU in ice packs and test drive it.
    Any other suggestions are appreciated?
    Thanks in advance.
  2. ASRDogman
    ASRDogman Senior Member
    7,809
    3,980
    When you had the plugs out did you look into the cylinders and see if #'s 1 and 2 were cleaner
    than the others? Which would indicate a possible head gasket leak.
    Since the egr cooler was completely clogged, that is a possibility.
    Are you loosing engine coolant? A "leak down" test is the best way to find out if it's leaking.
    And between #1 an #2 is the most common. Sounds like it is just starting, which is good because you
    catch it early and haven't overheated it and warped the head or bent a rod.
    You can search Prius Chat for more info, but certainly other's will join in..
    Mendel Leisk and Grit like this.
  3. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    that would be the first thing to do before plug n pray with many miles piled on. With a leaking head gasket, no matter what you throw at it, you gonna get the shakes.
  4. Norm K
    Buffalo
    Thanks for the input. looks like the head gasket. I did a very simple test. I removed the coolant pressure cap. No pressure on the coolant no misfires, and I believe I have been losing a small amount of coolant.
    Can anyone give me an Idea on how long it takes to replace the head gasket DYI?
    By chance does anyone know of someone in the buffalo NY area that might do this economically.
  5. bisco
    52,380
    sorry to hear it. idk, but try googling youtube, and there are threads here as well.
    not sure, but @NutzAboutBolts might have a video
  6. Hb-Marty
    Hb-Marty New Member
    Hermosa Beach
    Timing Belt
  7. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  8. Norm K
    Buffalo
    Update 8-6-21
    So I had the head gasket replaced all is good now.
    I changed the water pump also just because it also had 218,400 miles
    Here is list of the parts and labor cost just for everyone's reading pleasure.
    $700 labor + $20 misc parts done as a side job
    7/18/2021 218400 Head gasket kits & Head Bolts - rock auto $165
    7/18/2021 218400 Timing Chain Kit Amazon $109
    7/18/2021 218400 Coolant Toyota Pink Amazon $50
    7/18/2021 218400 Water Pump Aisin Amazon $216
    7/18/2021 218400 Oil And Filter $35
    Total Head gasket $1290
    Mechanic said it is the cleanest engine he has ever seen with 200K miles. Car has 218K miles.
    Mostly used Mobil1 full synthetic, and used some Pennzoil full synthetic. 10K mile change interval.
    I actually believe this problem started about 2 years ago, and that's what drove me to change the spark plugs and coil packs.
    I changed the water pump just because it was still the original. Aisin is the OEM manufacturer.
    I just treated it to a new set of front brakes, 70K miles on them. they likely would have passed NYS inspection but were close.
    I'll likely replace the inverter coolant pump and change the transmission oil in the near future.
    Good for another 100,000 miles !
    ASRDogman likes this.
