Intermittent no-ready no-start condition
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by koukilights, Oct 21, 2022.
  1. koukilights
    koukilights Junior Member
    Colorado
    I have a 2014 Prius with an intermittent no start. I'll unlock the car with the fob, get in the driver seat, press the brake pedal, press the start button, the dash will light up but the speedo and the "ready" light don't come on. I then turn the car fully off, try again, sometimes it works, sometimes it doesn't. Some times it takes 3 or 4 times of doing that, and sometimes even getting out of the car and locking it and then unlocking it and trying it all again to get it to start.
    But it always does start eventually. Brake lights do come on so that tells me the brake switch works. The problem occurs with both key fobs, one that actually has a new battery in it. Once started it'll run and drive no problem until I get to the destination. I'll turn it off and it'll turn right back on again. The no-start only sometimes pops up after it sits for a few hours.
    Any ideas?
  2. nicoj36
    nicoj36 Active Member
    518
    162
    It might be your actual 12v battery getting close to its end of life. If not, try resetting your ECU by disconnecting the 12v for a few hours and reconnecting. See if that fixes your issue.
    douglasjre likes this.
  3. koukilights
    Colorado
    Actually, that reminds me....I replaced the 12v battery before I took it on a road trip back at the beginning of the summer. It was an O'reilly's brand battery. I guess it could be a lemon going bad already? I'll load test it tomorrow.
    Does a weak batt just not have the juice to flip the HV batt solenoid so it just sits in auxiliary mode?
  4. douglasjre
    douglasjre Senior Member
    2,205
    736
    Null, NL
    Sounds like you left the battery terminal loose
  5. koukilights
    Colorado
    I'm 99% sure they're tight, I'll double check them and give them a wiggle tomorrow when I'm load testing it.
  6. ASRDogman
    ASRDogman Senior Member
    7,822
    3,984
    Did you charge the battery? Those places don't keep them charged.
    So it's been sitting on the shelve for a year probably.
    A weak battery causes a lot of problems.
    You didn't say how long the drive is but it's probably not enough to
    charge the battery. It's likely it's just enough so you can restart it after
    a short time, but not enough to keep the voltage high enough after several hours.
    You should charge the battery overnight, or at least several hours.
  7. koukilights
    Colorado
    Even if the battery didn't come topped off, how could it lose all it's charge after a few months? These cars don't draw a lot of current to start the engine like an ICE does. After it flips the solenoid for the HV battery pack, it's just hanging out getting charged up, isn't it? The long road trip this summer was 1500 miles 1 way. I'm sure the battery was charged to it's fullest during that drive.
  8. bisco
    52,391
    does the car sit around much?
  9. bisco
    52,391
    another thought, the brake light switch might need adjusting
  10. koukilights
    Colorado
    SOLVED - It was a bad 12v battery. I tested it and it came out to 10v and 220 CCA. It's a Super Start Platinum brand battery, manufacture date of 7/22.
    I'll be taking it into the store tomorrow to see if I can get it exchanged.
    nicoj36 likes this.
  11. nicoj36
    518
    162
    Make sure to get it covered by warranty. Tell em it left u stranded multiple times and had to get jumped by roadside.
  12. ASRDogman
    7,822
    3,984
    mmmmmm What do I know???????
    Grit likes this.
