Intermittent P0420 Check engine - Catalytic Converter replacement?
Discussion in 'Gen 2 Prius Main Forum' started by Raghav, Jul 28, 2024 at 7:41 PM.
  1. Raghav
    Raghav Junior Member
    35
    I am getting check engine light on with P0420 code. It goes away after some time, may be after 4-5 days, but comes back after about a month. Happened 2 times now. Probably it is in the border of going bad. I have inspection coming with a month left. From what I have read so far, I guess catalytic converter is the culprit and needs replacement for a permanent solution. Was looking at ebay, and EPA certified (atleast seller claims so) after market converter is around 50 bucks. Is it good enough? Approx how much will labor cost for the replacement? Any thoughts on cataclean? Does it work?
    TIA
  2. Tombukt2
    Tombukt2 Senior Member
    9,226
    1,618
    Durham NC
    It takes the muffler guy about 30 minutes to weld in whatever you bring him realize it aftermarket catalytic converters are not going to have as much material inside of them that's what the factory deems necessary for the Prius so you may never get the light off or it may go off for a minute and be playing the games is playing with you now If you live in an emissions state then you have to deal with this I don't and I don't.
  3. rjparker
    rjparker Tu Humilde Sirviente
    8,005
    4,743
    Texas Hill Country
    I would get a better cat that has worked for many. A Walker 16337.
    There is no way to clean a clogged cat, especially on the car using an additive.
