Intermittent problem reporting
Discussion in 'Tesla' started by bwilson4web, Jun 12, 2019.
  1. bwilson4web
    15,513
    As a former Prius owner we faced charges at Toyota of "Unintended Acceleration" in the 2008-2010 time frame. This led to a lot of technical investigation helped in part because the Toyota schematics were in the repair manuals. In one case, a college instructor connected a decade box (set of resistors) to the accelerator wires and with a reporter driving the car, flipped a switch and the car took off without an error code:
    Now the professor modified the Toyota wiring to induce two faults: (1) connecting two accelerator pedal inputs together, and; (2) setting a resistance that signaled full throttle. He converted a duplex system into a mono system and then set a fault . . . echos of the Boeing 737 MAX flipping between two angle of attack sensors which allowed one failed sensor to fly the airplane into the ground . . . twice. Without the schematics and a test part, I can't tell if something like this is possible in our Model 3.
    In the Toyota "Unintended Acceleration" case, the National Highway Traffic and Safety Administration (NHTSA) opened up an investigation and a lot of skilled investigators reported their findings including NASA. Toyota went with Hall effect sensors replacing the dual-pots and other manufacturers revealed techniques for detecting a wiring problem. One of the best was using different rates between the two accelerator position so a "short" could be detected. With parallel resistance rates, tying the two sensors together can not be detected. Add a second fault, a fixed resistance, and the car acts as if the accelerator was floored. So what data has NHTSA collected about our Model 3:
    2018 TESLA MODEL 3 4 DR RWD
    Scroll down and you'll see 57 complaints of which there were significant numbers of "Unintended Acceleration:"
    Date ID type
    05/22/19 11209238 acceleration
    05/15/19 11207877 acceleration
    05/07/19 11206155 acceleration
    04/22/19 11202909 acceleration
    04/16/19 11196764 acceleration
    11/30/18 11164094 acceleration
    11/26/18 11154132 acceleration
    10/03/18 11133222 acceleration
    09/28/18 11132177 acceleration
    09/01/18 11124067 acceleration
    08/02/18 11119991 acceleration
    07/27/18 11115496 acceleration
    05/22/18 11097159 acceleration
    05/10/18 11092830 acceleration
    05/04/18 11091970 acceleration
    HYPOTHESIS
    These intermittent failures suggests there may be one or more, random problems. For example, my cell phone failed to work as a key yesterday. So I cleared the problem by:
    1. Power reset iPhone
    2. Brake reset Model 3
    Unfortunately, I was in a hurry and did them in parallel so I can't identify a specific fault. A second example was when I lost Traffic Aware Cruise Control (TACC), I recovered it by doing:
    1. Display reset while driving
    Intermittent problems seldom occur in isolation. Resolving one can leave a second one that has to be identified and fixed. So we can't rule out a random, accelerator circuit problem. Absent analysis of the Model 3 schematics, there may be a fault mode that can lead to unintended acceleration.
    Recommended Follow-up
    • Document the problem - file both with the NHTSA and Tesla. It makes sense to first file with NHTSA and then cite the incident number in an e-mail via your Tesla Account email. Include any corrective actions and whether or not they worked. Be sure an include the software version and car VIN.
    • Serial attempts to clear - do one change at a time and see if it clears the problem: (1) iPhone power cycle if involved; (2) Display reset, and; (2) Brake reset. There is a "Power" option in the display software that may be included.
    49,397
    or maybe they're driving with two feet
  3. jb in NE
    jb in NE Senior Member
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    deleted - my error
