Intermittent Red Triangle of Death
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by scottso5, Jan 25, 2011.
  1. scottso5
    scottso5 Junior Member
    Monmouth Beach, NJ
    I have a 2006 with 106K miles. Noticed after making a sharp left turn in a parking lot that the Red Triangle came on along with a beep and the message, "Problem" on the touch screen. Started happening more frequently either when the wheel is turning left or if I'm driving straight and the car drifts a little towards the left if I'm on the highway. Today it happened about 6 times. Warning goes off after a couple of seconds.
    any througts?
  2. Patrick Wong
    18,200
    6,474
    Have you checked the engine oil level? Maybe it is low.
    If not, maybe your electric power steering system is starting to have a problem.
  3. scottso5
    Monmouth Beach, NJ
    Doh!!!! Dipstick was bone dry! Added a qt and still bone dry...... No leaks but I did notice gas mileage slipping. Remember having oil changed within last 6 months......
  4. Flying White Dutchman
    4,374
    313
    check for a (wiki)leak
  5. Mendel Leisk
    38,715
    That does not sound good. No oil on the ground? Try a bit more, and watch the underside for drips?
  6. scottso5
    Monmouth Beach, NJ
    After the one quart didn't show on the dipstick I drove it down the block to my local mechanic to change the oil. Then it snowed..... hopefully I will find out today or tomorrow if there is a leak.
  7. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    By "bone dry" did you mean that the oil level does not even reach the very tip of the dipstick (which is some distance below the "low" dot on the dipstick)?
  8. Patrick Wong
    18,200
    6,474
    In that case my guess is that your engine had <=1 quart of oil prior to your adding the quart. (Rated crankcase capacity is 3.9 quarts)
    The capacity between the lower and upper dimples on the dipstick is ~1.5 quarts. So, if the oil level was at the lower dimple you would have ~2.4 quarts. Since you said that you added 1 quart and did not register any oil on the dipstick, you certainly had no more than 1.4 quart to begin with, and more likely 1 quart or less.
    1) I am surprised that the low oil warning did not trigger earlier.
    2) I suggest that you keep an eye on engine oil level. This should be checked at least every other time you buy gas. You'll probably see that your engine is consuming oil fairly rapidly. The low oil level promotes rapid wear of the engine's moving parts.
  9. richard schumacher
    7,663
    1,038
    United States
    Always check the oil yourself before driving away from every oil change, no matter who changes it.
  10. Whitethug
    Whitethug Junior Member
    I had something similar on turns at least. What was happening is that I had slammed the door on my seatbelt a few times and the ensuing dent meant the door sensor wasn't connecting. My mechanic fixed it quickly with a shim, haven't had a problem since.
    At least worth a check. Very cheap fix.
