Intermittent Stalling (dealership no help)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by amandathegreat, Sep 17, 2022.
  1. amandathegreat
    amandathegreat New Member
    Oregon
    I have a 2007 Toyota Prius & need some advice. I am the 2nd owner & purchased in 2009.
    I’ve done all the regular/recommended maintenance & never had any issues until 2019.
    2019 (120,001 miles): the maintenance light was on so the car was due for an oil change, I fueled up before driving over Mt. Hood (in OR) & made it about 60 miles up the mountain when all the warning lights came on (red triangle, hybrid warning light, etc.) & the car wouldn’t drive. I had the car towed to the dealership & they said I ran out of gas & it was due for an oil change. I drove it home the next day (about 130 miles) & had no issues for 2 years.
    2021 (133,831 miles), same scenario: the maintenance light was on so the car was due for an oil change, stopped for fuel (my boyfriend was with me luckily so I had a witness that I put fuel in), started driving over Mt. Hood & made it slightly further when the car gave the same lights - this time also giving the “low fuel” light, we tried but the car would not take more fuel.
    Coasted down the mountain & made it to town. Once it sat idle for a few hours it started “normally” but got the same errors soon after so towed it home.
    The next day we read it could be from a bad 12v so we replaced the 12v battery & didn’t have any issues - until 2022.
    2022 (139,648 miles), similar scenario: the maintenance light was on so the car was due for an oil change, stopped for fuel, driving a long stretch of hills when the same errors came on & the car stalled. Towed it home. The next day it started normally, drove it to the dealership & they said the only code was “ran out of fuel”. Had them do an extensive inspection & they said it needed the serpentine belt changed (done), oil change (done) & transmission flush (done).
    Neither dealership has been able to tell what’s actually wrong with the car, only saying it’s run out of fuel - which isn’t possible, since it’s just been filled up each time.
    Has anyone encountered this? Would the fuel pump/fuel filter assembly and/or bladder tank be responsible for these intermittent stalls? Any guidance would be greatly appreciated.
    Thank you in advance for your time!
    52,371
    how many gallons were you able to put in?
    perhaps it is a balky fuel pump. i am assumong the only trouble code they could get was the out of fuel code?
  3. amandathegreat
    Oregon
    2019 I can’t be sure the gallons but I see the charge on my bank statement and it was $14 so probably around 4 gallons.
    (I was thinking even if that’s all the gas it had in it, I should have been able to drive 150 miles or so before it ran out.)
    2021 & 2022 put between 5-7 gallons in, I watch each time they pump now because I’m paranoid.
    You are correct, the only code they got was “out of fuel”.
    The only mechanic around that works on a Prius wants $2,500 to replace the fuel pump & I don’t even know if that’s what’s wrong. So figured I’d ask for any advice first. Thanks!
    52,371
    Unfortunately, I think the whole tank has to be replaced on gen 2 iirc.
    If the problem is intermittent, tracking it down could be labor intensive, involving a lot of testing of the pump, wiring circuit and etc
    amandathegreat likes this.
  5. bisco
    52,371
    It could even be a faulty ecu or corrosion on a connector
