Intermittent throttle/acceleration issues
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by scottwg, Feb 13, 2016.
  1. scottwg
    scottwg Junior Member
    63
    Atlanta GA
    My 2006 has started to slowly get acceleration issues. It is hard to describe. It started at low speeds. Usually in the morning when I left for work out of my neighborhood. I would start driving slowly, and without changing my foot on the pedal, my car would decelerate and then speed back up on a regular basis. The scary thing is that it would keep me from being able to pull out in traffic every now and then. Now it has started to do it at higher speeds when I am trying to get on an on ramp. It is much more subtle there. I only notice because of my experience at slower speeds. I had an "engine failed to start" alarm but it was a while ago and has not come back. But the issue is still there. I cannot tell if it actually is the engine not coming on at the right time, but that is the way I am leaning. I tried to look around for possible similar posts, but it is not easy to describe the problem. Any ideas, or links?
  2. Patrick Wong
    18,200
    6,493
    1. Odometer reading?
    2. Are any warning lights on?
    3. Are you current with performing all required maintenance including replacing the iridium spark plugs, the engine air filter, and cleaning the mass air flow sensor, throttle body plate and interior?
  3. scottwg
    63
    Atlanta GA
    220K
    No warning lights or check engine light as of now. I have not had one on for at least a month.
    The filter is new, mass flow and throttle body were cleaned one month ago. I was hoping that would be the problem. The only thing I have not done is change the spark plugs.
    51,155
  5. scottwg
    63
    Atlanta GA
    Should I hide my face when I say no?
  6. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    You've looked at the air, gotten good advice about the spark, next thing would be fuel--check the pressure and injectors.
  7. scottwg
    63
    Atlanta GA
    Will I be able to get the plugs at any regular auto supply store? I will do that today. I know they are iridium. Should I stick with a brand?
  8. Patrick Wong
    18,200
    6,493
    Get the correct iridium plugs as specified in the owner's manual. Denso or NGK only. Your discount auto supply may not carry them. Buy from your local Toyota dealer or order on Amazon.com
  9. scottwg
    63
    Atlanta GA
    My preference would be to buy them on Amazon. I have been burned buying some parts on line like the headlamps. What a rip off. It was almost impossible to get the real thing on line. Would you have experience knowing if that has happened with plugs?
  10. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    If you are concerned about fakes, be sure to buy the plugs that are supplied and sold by Amazon; makes returns easy. Don't buy plugs that are sold by Someone, but shipped by Amazon; you are subject to that person's return policy.
    If you are the original owner, take a close-up picture of the four plugs, esp the electrode area. I'm sure others want to see how worn the plugs are. You have plugs that went the distance. Factory schedule maintenance says to change at 12years/120K miles (12years/150K miles for CARB states). Most plugs look to be able to go a little bit beyond 120Kmiles.
  11. bisco
    51,155
    be prepared for a really difficult time removing them as well.
  12. scottwg
    63
    Atlanta GA
    Man, you guys are making me feel bad. But I did buy the car used. So with any luck, they were changed before I bought it. It had 180K on it when I got it, so I can only hope someone changed them before now.
  13. bisco
    51,155
    they were probably changed around 120k, and may not be the source of your problem.
  14. scottwg
    63
    Atlanta GA
    To be honest, I really don't think that is the problem. It seems to me to be a computer problem. To me it seems the engine is not coming on at the right time when it is called for so the electric motor does not give enough juice since it thinks the engine should be on. That is just my theory.
  15. Patrick Wong
    18,200
    6,493
    No problem. If you prefer to replace the engine ECU and the hybrid vehicle ECU instead of replacing the iridium spark plugs, then have at it.
  16. bisco
    51,155
    would the 'engine failed to start' alarm set a trouble code?
  17. scottwg
    63
    Atlanta GA
    I would love to replace the ECU. Can't imagine what that process is like. Yes, the 'engine fail to start' generated a code, but it was cleared by my mechanic when we tried to get it to do it again without success. So even though it makes sense that whatever caused the code is still my problem, it is not causing an error code any longer.
  18. bisco
    51,155
    i suppose it could be dirty fuel injectors.
  19. scottwg
    63
    Atlanta GA
    Possibly. Still feels electronic to me. I guess this is not a problem that comes up? I have been looking around PriusChat and discovered similar issues. But there have been many different diagnosis. And all issues have come with error codes. I might not be able to get this solved unless my car tells me what is wrong first. I would just like to strike first if I know what is wrong. Of course, this will bite me at the perfect time
  20. bisco
    51,155
    agreed. without codes, you're just playing whack a mole.
