Intermittent Wiper Fluid Leak
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by JBricks, Dec 13, 2015.
  1. JBricks
    JBricks New Member
    East Coast
    2012 Prius C
    Starting a few days ago, I noticed a wet spot underneath the front-right of the car.
    Turns out, I'm losing wiper fluid. I fill it up to the top, watch it for several minutes.. it doesn't move. Pull off, come back 5 minutes later and I've lost nearly half the tank... so it's leaking, or at least leaking worse when the car runs by way of something calling for it or the movement of the car.
    Anyway, I have to take it to the dealer this week for a airbag notice... I'm pretty mechanically inclined but there are about 200 miles left on the 36K/3yr warranty, so I'm hopeful this is a warranty issue.. and save myself the grief. hose slipped off, cracked, seal, something?
    Any thoughts on what this could be?
    My first thought was road debris caused a crack, but the splash guard seems to protect the reservoir pretty well... that'd have to be an awfully strange carem for a rock or something to take..
    #1 JBricks, Dec 13, 2015
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    They'll find the leak.
    If you are losing 1/2 a reservoir in 5 minutes the leak where ever it is coming from is not subtle.
    Whether the dealership defines the repair as a warranty issue? Well it would be nice. But if it's deemed an act of god or wear issue, you might have to pay for it yourself.
  3. JBricks
    JBricks New Member
    East Coast
    Funny. They couldn't reproduce the leak.
    49,504
    i'm not sure why it would change while you're driving. i don't think it's under pressure until you hit the button. if you can reproduce reliably, show them the full tank, and go for a drive, and show them the half tank.
    maybe there's a loose connection that leaks with vibration.
  5. JBricks
    JBricks New Member
    East Coast
    I didn't realize it held a full gallon, so I may have overstated when I said 1/2 a reservoir... It was probably closer to 1/4.
    In any case, I saw it visibly go down in a 5-10 minute drive...
    And to boot, the dealership checked it out, pressure tested, etc. Said it was fine. I even had them drive the car into the bay and we watched it together... no leaking.
    Doesn't make sense.
  6. bisco
    49,504
    nope. please let us know if it does or doesn't in the future. did you fill it when you took it to the dealership? maybe it only leaks until it gets down to a certain point.
  7. JBricks
    JBricks New Member
    East Coast
    I will...
    Other than a seal or a crack low in the reservoir, I'm stumped. Of course, either means the dealership straight up lied about their testing.
    The only other possibility I can see is a loose connection that they fixed by fiddling with everything and failed to mention it to me.
    Does anyone know if the reservoir is easy to remove?
  8. JBricks
    JBricks New Member
    East Coast
    So here's where I'm at and the timeline....
    Day 1 - Notice a decent sized puddle underneath the front-right of the car. It was late and didn't think much of it... figuring it was the A/C condensate.
    Day 2 - Car driven about 40 minutes, no wiper usage.
    Day 3 - Pickup some wiper fluid (by chance) at the store, come home and refill the reservoir. It took about 95% of the gallon. Noticed some drippage underneath, but I did spill some... though the drippage seemed like more than I spilled. After this, I watched the level for about 10 minutes.. no change. Took the car for a 5-10 minute drive, checked the level and it appeared to lose about 16-24oz. (My 1/2 and 1/4 gallons I stated earlier are probably overstated after viewing a picture of the reservoir online).
    Day 4 - Drove car for about 20 minutes, very minimal wiper fluid usage.
    Day 5 - Took car to dealership. When the car was in the bay, SOMETHING was leaking underneath.. but I assumed it was the wiper system given the previous facts and couldn't see, nor check color. May have been A/C condensate. Dealership checked for leaks, couldn't find any, but noted level was LOW. Consider this is after I put about 120 oz into it on Day 3. After talking to advisor, brought car back in bay.. observed for 5-10 minutes... no leaking underneath.
    Day 6 - Car driven for 2 hours, very minimal wiper fluid usage. Level appears to have hardly changed if any. No spots on driveway.
    Day 7 - Same as Day 6. No apparent level change. No spots on driveway.
    At this point, I'm clueless. Dealer suggested I may have overfilled tank on Day 3 and a "burp" or air bubble caused the appearance of lost fluid.. but why was it "low" on Day 5. What constitutes low? I have no idea.
    #8 JBricks, Dec 16, 2015
  9. bisco
    49,504
    great timeline. unfortunately, it does seem like some kind of anomaly at this point. is it filled to the top now?
  10. JBricks
    JBricks New Member
    East Coast
    It's just below the bottom of the filler neck... where the dealership filled it to... supposedly.
    You see, I didn't check it just prior to dropping it off at the dealer. So who knows what they did?
  11. bisco
    49,504
    that's par for the course.:cool:
  12. JBricks
    JBricks New Member
    East Coast
    Day 13.... Fluid level seems OK.
    So.. I guess this is DEAD. and remains a mystery.
  13. Mendel Leisk
    38,733
    I keep thinking maybe there's a loose joint in the filler neck, but not sure: it's significant amounts leaking out? I try to avoid filling up into that filler neck: that looks good for a dealership doing a "fluid top-up", but that bit's just a drop in the bucket, the bulk of the fluid is down lower.
  14. bisco
    49,504
    a mystery, wrapped in an enigma.
  15. Mo G
    Mo G Member
    317
    98
    Dallas,Tx
    Odd. Hope it's fixed.
  16. JBricks
    JBricks New Member
    East Coast
    Day 51 (and 2500 miles later) -- I go to fill up the reservoir and it only took about 12 ounces to top it off.
    I guess this is solved but I still don't understand.
