Intermittent wiper question
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by pdp, Nov 20, 2011.
  1. pdp
    pdp New Member
    162
    16
    Bay Area, CA
    In all the previous Toyotas I've driven, you'd turn the intermittent wiper knob "up" to slow down the wipers and "down" to speed them up. And this behavior corresponded with the marking on the wiper switch where the marker line would be thicker at the top (which I assumed to mean wider gap in time between wipes) and thinner at the bottom.
    However on our Prius v, the behavior seems backwards. While the markings are the same as other Toyota's, you turn the knob "down", toward the thinner part of the marker line to slow down the wiper and "up", toward the thicker part of the marker line" to speed up the wiper.
    Is this the correct behavior for the Prius v, and/or Prius hatchback, and/or all recent Toyotas? Or is this just a quirk with ours?
  2. dtuite
    dtuite Silverback
    182
    31
    Redwood City, CA
    do not know about history, but if you turn the knob "clockwise" as seen from the end, the blades cycle more often. seems like standard human factors.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I have no v but my interpretation of the markings is the same as the OP's.
    FWIW, the direction in which the knob should be turned to increase/decrease the delay between wipes is reversed between my 06 Prius and my former 04 Nissan 350Z.
  4. tomtomsf
    tomtomsf Junior Member
    36
    Half Moon Bay
    The intermittent wiper control turns in the opposite direction from my previous Nissan. I found it took me long time to get used to it.
    Now, the knob for the rear wiper is confusing. To this day, after one year of ownership, I can not simply turn on the rear wiper without washing the window first. I don't know why they made that knob so tricky to use.
    Tom G.
  5. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    I used the wipers today on my 06 Prius and found that turning it up (towards front of car) increased the interval between wipes (slowed it down) and that also corresponded with the longer/wider line.
  6. Tideland Prius
    16,125
    We had this discussion when the 3rd Gen Prius debuted in 2009. That's when Toyota started switching their variable intermittent wiper knobs around.
    The idea is going from interval timing (old method) to frequency of wip (current method). It took me a while to get used to it too as I kept rotating it down to increase the frequency of the wiper (decrease the pause between wipes) and decreased the frequency instead.
    They've gone to a lot of standardization with the new models and the variable intermittent wiper is just one part of it. Others include the CRUISE light replaced with a speedo and an arrow pointing at some part of the speedo (add a car to the symbol if DRCC is engaged), the headlight stalk now just has symbols with "AUTO" being the only word (OFF is replaced by O)
    The wiper stalk's "MIST, OFF, INT, LO, HI" have also been replaced with graphics. Ditto the rear wiper.
  7. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    I wonder if the above replacement w/icons and symbols is to reduce localization costs. There are fewer parts that need to differ depending on the local language of where the car is sold.
  8. Tideland Prius
    16,125
    Could be but I'd like to give them the benefit of the doubt and say that it's more for standardization for people whose first language isn't English and to make it easier to move from manufacturer to manufacturer with standardized symbols.
  9. pdp
    pdp New Member
    162
    16
    Bay Area, CA
    Thanks for clarifying this, I was just afraid it was a fluke where two wires were crossed in our new Prius v.
    Just curious, what standard are they supposedly standardizing to? I haven't driven many cars newer than 2007, but pretty much every one I've driven with intermittent wipers have the "current method" you mentioned. Also, it's funny how the Prius v "standardized" the behavior of the intermittent wiper knob direction but did not standardize the "MIST, OFF, INT, LO, HI" because they're still letters, not graphics!
  10. Tideland Prius
    16,125
    No idea. Maybe just within Toyota global vehicles?
    LOL. That's hilarious. I'm pretty sure they're graphics on my 2010 (while they're words on our 2005). Interesting mix.....
