Internal door panel mark.
Discussion in 'Gen 4 Prius Main Forum' started by Dragon Rider, Jan 5, 2017.
  1. Dragon Rider
    Dragon Rider Active Member
    344
    211
    Miami
    Can anyone suggest the best way to remove scuff marks from an internal door panel.
    The scuffs have been caused by someone getting out of the vehicle and catching their shoe against the panel which is plastic with a raised pimple effect pattern. I tried Quick Detailer but this had no effect at all. I try Magic Eraser it did not worked.
    Thx.
  2. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Can't be sure, but on other cars I've had a soft damp cloth can work wonders. No great expense as I would not encourage the use of solvents - just in case....
    Dragon Rider and bisco like this.
    49,490
    i always scuff mine. no luck getting it all off. prius interiors are notoriously difficult to clean. something to do with the cabbage based plastics. warm water and dishwashing liquid or spray cleaner.
    RCO and Dragon Rider like this.
  4. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Wire wool is out of the question, then?
    Back in the sixties the type-hammers of teleprinters had to be cleaned regularly. What they used then is now retailed as blue tack. I know it's kind of oil based so it might be worth a try. Up to you, D.R.
    Dragon Rider likes this.
