internal temperature sensors?
Discussion in 'Gen 2 Prius Technical Discussion' started by onlynark, May 26, 2007.
  1. onlynark
    onlynark Member
    189
    bay area
    I am wondering if the prius has any internal temperature sensors. I know you can set the desired temperature you want in the car, so how does the prius maintain this temperature?
  2. Tom6850
    Tom6850 Retired
    898
    Leesburg, FL
    The sensor is located on the left front of the dash. It also checks humidity.
  3. SomervillePrius
    SomervillePrius New Member
    944
    Somerville, MA
    What tom said, but there is (unfortunately) now way to see current inside temerature.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    <div class='quotetop'>QUOTE(SomervillePrius @ May 26 2007, 07:03 AM) [snapback]450321[/snapback]</div>
    You may not be able to see the interior temperature displayed, but if my wife is with me, I know that the temperature is either:
    1) Too hot,
    or
    2) Too cold. :D
    I've though about changing the thermostat to a toggle switch labeled with those two states. ;)
    Tom
