Interstate driving
Discussion in 'Prius c Main Forum' started by Noobprius, Feb 9, 2017.
  1. Noobprius
    Noobprius Junior Member
    43
    16
    US
    Hey guys! I have an 06 prius and I'm thinking of maybe upgrading to a used prius c. I like the car because, personally, I think it looks better than the normal prius, and I believe used ones run cheaper. My only problem is that I drive 80 -100 miles round trip everyday, and 40 miles of that is 70+ mph. I heard that interstate driving is an issue with this car. Any thoughts?
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    It is the same engine you have in your 2006, so it is no less able to do your commute. While it is less aerodynamic than the Liftback, it will certainly serve that purpose. MPG is not everything.
  3. Deogratias
    Deogratias Member
    37
    42
    Drive one and see how it suits you. I think everybody has their own opinion on this.
  4. News to me.
    70+ mph speed likely causes your engine to rev closer to 3000 rpm than 2000 rpm for the trip. It'll handle it. And you're still getting 40 mpg.
    Noobprius likes this.
  5. Got2bHam
    Got2bHam Member
    155
    51
    Missouri
    IMG_0480.JPG This is from my last interstate trip, I drove 65-75 mph. Love the C
  6. coyote303
    coyote303 Member
    112
    64
    Colorado
    If the majority of my driving was on the Interstate, I would go with a regular Prius. The C can handle freeway driving just fine; however, it won't be as efficient as a regular Prius.
  7. davidc83
    davidc83 Member
    113
    50
    Scottsburg, Indiana
    2015 Prius c
    2015 C two, now with 34,000 miles, 80 mile round trip to work. 80% of miles on interstate - no issues.
    XT830C ?
    Pri3C likes this.
  8. AzraelA
    AzraelA Junior Member
    Mars
    At 70 MPH I find the MPG really drop, generally I find that unless it's time sensitive to be somewhere I drive 63 MPH and it gets me about 53 MPG in my '13 Prius C.
  9. Mark323
    Mark323 Junior Member
    69
    I've had no problems driving on interstate roads with my Prius C. Sounds like some alternative facts are being thrown around about the C's capabilities on the highway. I routinely get in the 40mpg + range on the highway doing well above 70mph X 40 miles a day, It's difficult to get less than 40mpg in this car. I recently bought some regular tires (not LRR) and they have improved the feel of the car on the highway. I think the LRR tires gave the C a bit of a wandering feel on the highway, & that sensation seems to be gone w/ the new tires. The OEM tires lasted 50K miles (prob because of all the high speed highway miles I put on them) I've taken this car all over the east coast on road trips. My wife and I visit at least one National Park every year. It's been Down to FL 3 times (only 3 fill ups to Florida from Maryland), Up to Cleveland Ohio, Out to Kentucky (Mammoth Cave), Down to N. Carolina (Great Smokey Mountains) and out to Ocean City, Maryland and to the Chesapeake Bay Bridge Tunnel into Virginia Beach.
    Pri3C likes this.
  10. priusmatty
    priusmatty Active Member
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    I have driven a C for years in the interstate and highways with no issues whatsoever.
    Pri3C likes this.
  11. rjdriver
    rjdriver Active Member
    406
    168
    Rhode Island
    Not sure about the 06, but I test drove a regular Prius and a C before buying my 2012 C. The regular Prius was quieter and smoother over bumps at highway speeds, but the C is just fine on the highway. At the time I had an 80 mile round trip commute (half highway/half city-back roads - similar to yours), so I was willing to sacrifice a few things for the higher MPG. And the lower price helped sway me as well.
    Your results might vary, but I have found that the in the C gas mileage begins to suffer a lot when you get over 70 mph. That seems to be the tipping point between over or under 50MPG for me. On the back roads section of my commute where speeds ranged from 30-45 mph, I was getting 70 MPG.
    The usual caution in buying a used Prius would be to try to find out the remaining life of the hybrid battery before buying. Odometer reading is a partial help, but if the seller is willing, you might want to look into doing a test with the Dr. Prius app.
    Hybrid battery diagnostic and repair tool for Toyota and Lexus
  12. Adventurer2112
    Adventurer2112 Junior Member
    29
    16
    Urbana
    2014 Prius c
    Hi All,
    Highway driving was my big concern. After 2,000 miles, I have no worries. Yes it is slow to merge, just have to plan.
    I am tickled pink with my 2014 Prius C
    Jack
    Pri3C likes this.
