Interstate MPG
Discussion in 'Gen 2 Prius Fuel Economy' started by darkydog, Feb 27, 2006.
  1. darkydog
    darkydog New Member
    Iowa
    I live near Iowa City, IA I have had my new 06 about 2 weeks now, about 1300 miles on it. I have been getting around 50mpg on local roads and city, but only about 36 on a trip on the interstate. The area here is pretty hilly and I was surpised to see 50mpg locally.
    A week ago three of us with light luggage made a trip to Milwaukee, about 260 miles each way all on interstate. There are few flat spots on the trip but even where it was flat I was still only getting in the 30's. I was varying speed between 60 and 75 because I was still breaking in the engine. It was single digit temps and there was a 20+ head wind going up and 20's with less wind coming back. I actually got slightly better milage on the way up. My question is do things like temps and wind really make that much difference or does mid-thirties seem a bit low?
    With the cruise on there really isn't much I can do to affect the milage and it's not very practical to drive 45 or 50 on an interstate. I read where others are getting 50+ mpg and wonder what's going on.
  2. RonH
    RonH Member
    556
    At freeway speeds, drag is the most significant factor, by far, drag force almost proportionate to speed squared, power to speed cubed! And headwinds add on and cross winds can give significant apparent head winds (vector add). That being said, on my trips from San Diego to Barstow and back I usually get low 40's on the way there and high 40's on the way back (~3000' elevation change), speeds varying between 70 and 80 mph. And when the winds blowing in the Cajon Pass, it drops. YMMV!
  3. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    What speed were you trying to maintain with CC? Also, I've found that CC is pretty aggressive with its speed maintenance. I think that this is particularly true in hilly country. I used it once on a 10 mi trip to Boulder, CO and found that I did much better without CC, in terms of MPG. You might wanna try the same trip w/o CC and see how you fair.
  4. jwe8f
    jwe8f New Member
    174
    Indiana
    Varying your speed is not necessary (nor specified by the owner's manual), and may be causing you problems with your milage. Cold doesn't help.
  5. RonH
    RonH Member
    556
    Once its warmed up, why does cold matter, unless you're able to get the ICE to turn off long enough to cool down and thus come back on sooner? I don't think I could do that at highway speeds. If you're running the AC as a heat pump that will be some load, but if the AC is off you're just heating the cab with waste heat + some energy to turn the fan.
  6. jwe8f
    jwe8f New Member
    174
    Indiana
    Like I said, varying your speed is not necessary (nor specified by the owner's manual), and may be causing you problems with your mileage.
    Also, to elaborate, cold is cold. Your engine runs longer to maintain a constant temperature. Period. At highway speeds the heat loss is greater.
  7. HybridVigor
    HybridVigor New Member
    96
    Chandler, AZ
    Is this completely true? My understanding was that the Prius heater was electric, explaining why you can get instant heat in the morning without having to warm the car up. If this is the case, then running the heater at any time would draw battery power and cause engine drag from increased MG2 usage, dropping your mileage.
    I do fairly little highway driving (just under 30% of my miles) and it tends to be in chunks since my daily commute doesn't involve the highway. What I've seen from the couple of highway trips I've taken, cold definately affects your highway miles. I did one 100-mile trip at 70 degrees (~52 mpg) and another at 40 degrees (~45 mpg) and drove them in similar fashion (CC at 70 mph, approximately.) Very flat driving, by the way, making cruise control very efficient. I do believe I used the heater during the colder drive, but only sparingly.
  8. Frank Hudon
    Frank Hudon Senior Member
    4,147
    the electric driven A/C compressor on the Prius is NOT a heat pump its' a variable speed scroll compressor only. If you are on the hi-way and you have it on Auto the compressor runs at the speed that the humidity sensor determines that it needs to condition the air going thru the evaporator/heater assy. Also the heater in the Prius has two small electric heater elements embedded in the core that provide supplemental heat when the flow control valve has the coolant diverted to the ICE from the thermos
  9. malorn
    malorn Senior Member
    4,281
    59
    "Somewhere in Flyover Country"
    Most of you will say I am just trolling, but we have taken in 5 priuses in trade over the last 2+ years and all but one were because of dissapointing highway mileage. Mid 30's was all folks were getting.
  10. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    Yeah, I'm disappointed (note the sarcasm) with 36 MPG at 10 degrees F and 30 (yes, thirty!) plus MPH headwind going uphill (about 600 feet elevation to 3200 elevation over 150 miles). Speeds are 65 MPH.
    Same trip with LOTS better conditions (warmer, less windy) I get 49 MPG.
    Stupid people. No other changes except weather. It's just so hard to get people to realize they don't drive in a lab on rollers no faster than 48 MPH.
    Sheesh...wonder what their non-Prius will get...oh, wait, they'll never know or care since many cars do not show you instant and tank MPG.
  11. HybridVigor
    96
    Chandler, AZ
    I'd be disappointed too, if I was getting 30 mpg. Trade the car in? I'm not sure I'd do that, but I'd be much more inclined to consider it at 30 mpg.
  12. daniel
    14,487
    1,518
    Spokane, WA
    The reason you don't vary the speed during the break-in period is that the revolutionary power train of the Prius almost entirely de-couples engine speed from vehicle speed, such that the engine varies speed on its own, and changing vehicle speed has minimal effect on engine speed.
    At 75 mph against a 20 mph tail wind your wind speed is 95 mph. You'll take an ENORMOUS mileage hit, due to wind resistance, which is proportional to the square of the speed.
    Cabin heat comes almost entirely from engine waste heat. With the cabin heater on, the engine must run more to stay hot enough to provide that heat. A conventional car has its engine running 100% of the time, so provides excess heat. The Prius gains effenciency partly by shutting off the engine when it's not needed, but running the cabin heater prevents the car from doing this as much, thereby forfeiting some of its potential efficiency gain.
    I've never taken a long winter road trip, but in ND (with its nearly-constant high winds) I generally got low 40's for mpg at 75 mph. If you got mid-to-upper 30's in an Iowa winter, I'd say that could be reasonable. Slowing down will help a LOT. Turning down both the temp setting and the fan speed, and wearing a sweater, may help also. Wearing a parka and bunny boots and shutting off the heat entirely will help even more, though the engine still have to run more to keep itself warm. And this may be much less significant on the freeway, where the engine runs constantly anyway.
    Seems to me I've seen below-40 mpg at 75 mph against a fierce headwind.
  13. tripp
    4,717
    79
    Denver, CO
    Varying your speed on a flat surface that's probably true, but with hills I think it makes a lot of sense. Why accelerate hard to maintain a certain speed on the uphill and then brake to maintain that speed on the subsequent downhill? I generally ease things off on the uphills and build up a good head of steam (within safety limits, of course) on the downhills. That extra momentum helps me crest the next hill using as little energy as possible while still maintaining a safe speed.
  14. jef
    jef New Member
    84
    Inglewood (Los Angeles county), California
    I strongly suspect that the entire issue is weather.
    I am blessed to live in a very mild climate and I find that travelling 65-70 mph on highways, with occasional slower sections due to heavy traffic, I have been exceeding the EPA highway estimates, getting above 50 and as high as 52.5 for long stretches.
    If only I could do something about the shorter trips to work in the morning.
  15. kirbinster
    kirbinster Member
    602
    Morris County - New Jersey
    Weather is a major issue. Headwinds at 75mph will kill the mileage. Remember this is a light vehicle so there is much less momentum than a big car so wind and high speed will have a bigger impact. Also, cold single digit temps will force the engine to work harder to maintain temperature of the engine, exhaust system and passengers.
    Not sure why your mileage is that bad, probably just the speed. In the NY.NJ area I typically do about 60-65 mph and on the highway in my Classic '02 Prius get about 50 mpg. In the winter that will drop to about 46 mpg, but never in the 30's. To get in the thirties I would have to hot rod from lights and drive like a total fool - even then I am not sure it would drop that low.
  16. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Finman you have got it. EPA is a lab test done under standard conditions. Variables are decreased or eliminated from car to car. Shoot you could pull the body seats and just do it with the drive train they really are not necessary for the test. Given all of that if you asked me to design a test to compare one car or truck with another I would think that the EPA would be an OK way to go. Now if you want it to reflect the real world you would have to change the test entirely. You would need many cars over many hours in all kinds of weather and road conditions. Boggles the mind. Could the EPA make a few changes to better reflect real world and still decrease the variables and make it a valid test? I would say yes I for one would like the highway speeds increased. The bottom line is your mileage will vary! Trite but never the less true. People don’t get it and don’t care. Yet! The end is near! :eek:
  17. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    All you have to do is drive the Prius like it is a plane. When you are going into a headwind your ground speed should be lower. When you have a tail wind you can go faster to make up for the time loss on another trip. Should be easy to stay over 50 mpg at least on the highway.
    But even with no wind you can't expect good mpg even up to 40 mpg if you drive fast in cold weather.
    Even 30-40 deg F will seriously kill your mpg if you drive over 60 mph or so. If you like to drive 80 or 90 save it for summer.
  18. Schmika
    Schmika New Member
    1,617
    Xenia, OH
    If I had to venture a guess, the OP was going closer to 75 than 60-75. I also suspect the OP was aggressive to make sure they sayed 75 on the uphills. NO CAR is going to do well on mileage in that. We have had low teens temps here and the lowest my mileage go was 41. Of course, I don't drive over 65.
  19. darkydog
    darkydog New Member
    Iowa
    I had to leave right after I posted last night and this is the first I got back. Thanks for all the suggestions. I have also tried several things in the meantime. Yesterday I went out on the interstate, set the cruise, temnps about 40 and again a bit of a headwind and still got in the 30s. My wife used the car the last few days, driving the same interstate as part of her commute. She averaged over 46mpg and I know she didn't change her driveing (fairly agressive) to improve milage, but she didn't use the cruise. Tonight I had 4 adults and a 13 yr old on the same route and averaged 46 without cruise. It does seem to be the cruise causing the problem. As I said before, it is pretty hilly here and it must really take a toll on the uphill and not gain much on the down.
  20. tripp
    4,717
    79
    Denver, CO
    That's what I've discovered here in CO. The cruise is aggressive on the uphill but then backs off on the downhill to keep the speed as close to the target as possible. The downhill part is the real bugger because you loose out on letting gravity help out. Glad to hear that you're seeing a marked improvement.
