Intriguing...so the little cars are deceptive?
Discussion in 'Gen 2 Prius Fuel Economy' started by cdub1955, Apr 18, 2008.
  1. cdub1955
    cdub1955 New Member
    Lexington, KY
    Pulse & Glide and the regeneration cars?
    Okay, so I have been 'researching' this pulse & glide methodology. And it would appear, correct me PLEASE if I am wrong, but driving up the little cars in the bars is a bad thing?
    is that correct? Assuming that the little cars represent kenetic energy being driven back into the battery, which you 'don't want to do un-necessarily.
    is that correct?
  2. jdonalds
    jdonalds Active Member
    541
    225
    Redding, California USA
    If the question is should you avoid EV altogether like most things in this world "it depends." If you are using the P&G on level land the idea is not to run in EV, don't use the battery, so don't recharge the battery.
    However there are cases where using EV makes some sense and if you can get regen to charge the battery it can save gas. The ideal case might be stop and go traffic where you are on EV all the time, followed by a perfectly placed downhill to recharge. Even when using P&G in low speed conditions there will be traffic signals that will sometimes turn red. I will coast as long as I can to slow leading up to the red light but will drop into regen so I don't have to use brakes.
    I've also found on long trips I can improve my mileage when the road is a series of small hills while not causing any real elevation change. On highway 5 in California there are places where the hills are 100-200 feet high. Go up the hill using both ICE and EV then regen on the way down.
    None of these cases involves stacking up lots of "little cars in the bars" though.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    The little green cars are a bad thing, but if you have to brake, they are better than nothing. For maximum gas mileage, you want to drive at a steady speed without every accelerating or slowing down, and have an engine perfectly matched to that one load. Obviously it can't be done, but you can try. The little green cars mean you have recaptured some energy that would otherwise be wasted, so that is good, but they also mean you have been using the brakes, which is bad. It doesn't make sense to worry about them, but don't pride yourself on how many you get.
    Tom
  4. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    You're right on target. The green emblems indicate regenerated energy, converted from kinetic energy to electric energy to stored chemical energy, with conversion losses on the way and back again when it is later used. Better is to let that kinetic energy go to work for you immediately and most efficiently by gliding instead of regenerating.
    I look at this way: Every time I coast (foot totally off the go-pedal) I've wasted a little fuel. Every time I brake regeneratively I've wasted more. Every time I use the friction brakes (a hard stop or any braking below 7 MPH) I waste even more. Certainly some of this waste is unavoidable, but part of getting maximal fuel economy is route planning and anticipatory driving to reduce the need to decelerate with anything but gliding.
  5. cdub1955
    cdub1955 New Member
    Lexington, KY
    JimboK, I just saw your video on youtube...very cool.
    I noticed a 'summary' screen on your display. I am new to the Prius (2007 model), how do I get to that summary screen?
    Thanks,
    chris
  6. JimboK
    2,817
    187
    49
    Chesterfield, VA
    Oops, Chris, I missed this after you first posted it. :sorry:
    Thanks for the kind words. The summary screen you saw is probably the one from CAN-View, an add-on device that is no longer available except to those who are converting their Prius to a plug-in version.
