Intro to DTC
Discussion in 'Generation 1 Prius Discussion' started by bwilson4web, May 2, 2010.
  1. bwilson4web
    15,964
    I've been unhappy with the poor state of NHW11 documentation for the Diagnostic Terminal Connector so not being one to 'curse the darkness':
    The photo is of an extension connector that has both a male (OBD/scanner connector) and female connector (the vehicle body.) I bought a Y-connector and will use it to measure layer 1/2 signals from Auto Enginuity. But the "Ts", "Tc" and "CG" pins are useful for those who need a cheap diagnostic, the "SST":
    • Tc to CG - triggers two-code errors to flash on the corresponding ECU lights after turn ON vehicle
    • Ts to CG - closed 4 times in 8 seconds - clears the codes
    You'll need to check the instructions for the different ECUs. For example, the power steering (EMPS) calls out for a 1 k resistor and LED connecting signal WL to PGND (signals on two connectors, pp. DI-464) for to work. However, the ABS ECU does not appear to require anything special. Check the maintenance manual for the exact instructions.
